f250 trans
Old Nov 19, 2003 | 09:40 PM
krh427's Avatar
krh427
f250 trans
What was the best manual trans for a 66 f250? New Process, Borg Warner or ???
Is there anthing else that will work on an FE that makes sense?
Old Nov 20, 2003 | 07:35 AM
barry's Avatar
barry
THe new Process 435 is a good tranny, I've had a few behind FE engines and never a problem. They are plentiful if you need one.
Old Nov 20, 2003 | 11:45 AM
6t6merc's Avatar
6t6merc
I have the NP435 and it works pretty well, although it is a truck transmission and shifts slowly and has less than optimal gear ratios. Like many others, I would like to have an o/d, but I'm put off by the cost of a NV4500 or a GV o/d. The option I'm now considering is a passenger car toploader with the truck-style tower shifter modification. No o/d, but better ratios and easier shifting.
Eric
Old Nov 21, 2003 | 08:02 AM
krh427's Avatar
krh427
What is a NV4500 or a GV? Are they an option?
Old Nov 21, 2003 | 10:22 AM
6t6merc's Avatar
6t6merc
The NV4500 is a 5 speed o/d trans used by GM and Dodge in recent years. The Gear Vendors o/d is an add-on unit that attaches to the rear of the transmission.
Eric
Old Nov 21, 2003 | 10:42 AM
krh427's Avatar
krh427
Will the NV4500 bolt up to the FE without too much trouble? What do those transmissions typically cost? Where can I find more info?
Thanks
F-250 restorer
Jul 2, 2014 05:26 PM
wantaford
May 11, 2010 10:43 PM
SBK
Mar 5, 2010 05:32 PM
cebru
Jun 10, 2006 11:46 PM
fordmanSLO
Oct 11, 2001 06:57 PM
