2006 6.0 Glow Plug issues
Old Aug 7, 2023 | 07:14 PM
Smudge38's Avatar
Smudge38
4wd High
Hey all,
I keep getting an error code for glow plug, would this cause hard startup and hesitations while driving?
is this an issue that should be resolved ASAP, am I causing damage if I drive it still?
thanks.
Old Aug 7, 2023 | 07:36 PM
6point0's Avatar
6point0
Glow plugs can definitely cause a difficult start. The glow plugs shouldn't cause any running issues at all.
Old Aug 7, 2023 | 07:55 PM
HEUI Lewis's Avatar
HEUI Lewis
If it is warm where you are, I doubt that you'd experience start-up trouble.... Is it a long crank?
Old Aug 7, 2023 | 11:07 PM
Smudge38's Avatar
Smudge38
4wd High
sometimes takes a short bit o fire up
Old Aug 7, 2023 | 11:09 PM
Smudge38's Avatar
Smudge38
4wd High
I’m thinking the hesitation while driving might be the EGR valve, since they make us have one on our diesel here in California (dumbest thing ever!)
Old Aug 8, 2023 | 08:57 AM
xcrsp440's Avatar
xcrsp440
What data reader are you using? Otherwise, without codes or data you are guessing and that gets real expensive.
Old Aug 8, 2023 | 12:03 PM
bismic's Avatar
bismic
If the glow plug system has excessive electrical draw, it cis possible for it to cause a crank, no-start. Typically it is a GPCM failure that could result in the significantly increased current draw (enough to drop the PCM power voltage). Not particularly common though.
Old Aug 8, 2023 | 10:56 PM
Smudge38's Avatar
Smudge38
4wd High
actually I have an Edge tuner on the truck and it will give me error codes. I will update next time I’m in the truck.
Old Aug 9, 2023 | 05:41 AM
TooManyToys.'s Avatar
TooManyToys.
Gonna need something better than that. Forscan is the recommended choice for those of us that have been working with these trucks for over a decade.
bulletproofed7124
Oct 23, 2021 09:06 PM
TheDuke
Aug 22, 2021 03:57 PM
Tom Callan
Nov 2, 2014 11:43 AM
newbie2006
Sep 19, 2014 12:04 AM
Hwilli
Feb 22, 2013 04:14 PM
