Does anyone know the size of the glow plug o-rings for a 6.0? I've searched around for this and the only info I found indicated OD is ~ 8.5mm.
edit- 8.5mm couldn't be correct, I am guessing that is the bore below the sealing surface. Last thing I found seems to indicate the OD of the o-ring is around 17.1MM.
For reference actual dimensions
13/16" OD, 9/16" ID 1/8" section width
My OE harness o-rings appeared to be silicone as they were red/white but the replacement ford part appears to be garden variety buna nitrile part# W300965
