Replacing engine crossmember?
Old Aug 6, 2023 | 01:46 PM
nova801428's Avatar
nova801428
Hello,
I've done some modifications to my engine crossmember and I would like to go back to stock. I know the crossmember is riveted to the frame but is it still possible to replace? This is on an '89 Bronco. Will any 4wd crossmember work?
Thanks!
Old Aug 6, 2023 | 03:15 PM
My4Fordtrucks's Avatar
My4Fordtrucks
That would be a lot of work. I’m not sure but I don’t see why not. The engine mounts can also be replaced separately from the crossmember so I would think that the crossmember is the same part for all of them.
Old Aug 6, 2023 | 03:37 PM
nova801428's Avatar
nova801428
Thanks! I'm not using stock engine mounts anyway. I notched a big section out of the crossmember, welded on motor mounts, and moved the drivers side ttb mount. It's a lot of work but may be easier than trying to weld it back to stock.
1985 Bronco
Feb 28, 2019 06:15 PM
lowtrkn2k
Aug 27, 2012 03:59 PM
Pappys53
Apr 18, 2010 11:21 AM
54FordF1shortstep
13
Nov 29, 2009 09:48 PM
1oldtimer
Oct 12, 2009 10:40 PM
