P0705: Transmission Range Sensor Circuit Malfunction (PRNDL Input) on my 2002 EX V10.
I was able to use Forscan to run some live data. The shifter position is correct between the column, transmission and in the live data. Does anyone know if the live data is coming via the range sensor or is it misleading me?
Of the typical issues with this code I only have the CEL.
Check Engine Light. Yes
No start (park or neutral) No
No dash indicator (PRNDL) No
Erratic shifting No
No Reverse lights No
Having to wiggle shift lever start No
Having to put vehicle in neutral (N) to start No
Thanks for any input.
Reason: Typo
