Sponsored by: Real Truck
'03 Engine Dies!!
Old Nov 19, 2003 | 08:52 PM
BigDawg54's Avatar
BigDawg54
Angry '03 Engine Dies!!
heres my story, i start the truck up at around 5am this morning temp about 40 degrees out. no problem. i head up the road to go to my hunting spot, pull into a hayfield slowly and my engine just dies!!! nothing, steering locked, but electrical system was still working (headlights). i was absolutely beside myself. i let the truck sit for a second and tried to start it up. sure enough it started right up no problem. to say the least im a little pissed and confussed. what do you guys think happend?? its bran freakin new!! you have got to be kidding me. plus ford needs to start selling real AT tires on their trucks, these general ameritracs are garbage, i get stuck in a field that is practicly level! not a happy camper so far.
-bigdawg
Old Nov 19, 2003 | 10:01 PM
99f350sd's Avatar
99f350sd
Should of took the Dear.........John that is
Only kidding. Were you off the gas. Maybe the idle control. They seem to be causing lots of headaches..
Old Nov 20, 2003 | 04:33 AM
user 708242442's Avatar
user 708242442
Bring it to the dealer and they will change the PCM.
Old Nov 20, 2003 | 09:42 PM
BigDawg54's Avatar
BigDawg54
hey guys, what is a PCM? and yes if i recall correctly i let off the gas to roll into the field
-bigdawg
Old Nov 20, 2003 | 10:59 PM
99f350sd's Avatar
99f350sd
If it does it again I'd check the IAC motor.....Idle air control.
Old Nov 21, 2003 | 04:16 AM
user 708242442
Bring it to the dealer. Don't wait for it to happen at the wrong time again.
Old Nov 21, 2003 | 07:29 AM
Bob Ayers's Avatar
Bob Ayers
-bigdawg
Power Control Module --- This is the computer that controls the motor, and transmission......
Old Nov 21, 2003 | 05:41 PM
BigDawg54's Avatar
BigDawg54
thanks guys, i need an oil change and tire rotation next week so i'll have them check it then.
-bigdawg
Old Jan 30, 2004 | 07:09 PM
BigDawg54's Avatar
BigDawg54
ok, so my truck did it again. was backing into a driveway, and took my foot off the gas and.....blah....nothing. she just died once again. both times have been when i took my foot off the gas, in cold weather, going slow, and it started right back up. never had it checked the first time, fig it was just some freak thing. but i dont want the 3rd time charmer to be going 65 down the hwy. guess my baby is goin to the doctor, any advice besides what was said the first time? anyone else have this problem?? maybe a vapor lock or something in the fuel line??? i dont know im lost for words.
-bigdawg
Old Jan 30, 2004 | 07:22 PM
99f350sd's Avatar
99f350sd
bummer
Old Jan 30, 2004 | 08:52 PM
Buzz Cut's Avatar
Buzz Cut
sounds like a chafed wiring harness. there is a TSB on it. seems the harness can rub on a bolt at the top rear of the valve cover[cannot remember which side] and short causing the stalling issue.
Old Feb 1, 2004 | 04:18 PM
easmythcrna's Avatar
easmythcrna
That sounds exactly like what my '01 F250 did. If I took my foot off the gas, it would die. Kept restarting and dying every time I took my foot off the gas until the engine warmed up enough (about 10 min). Dealer replaced the Idle Air Control valve under warranty.
bigdawg460
Oct 14, 2009 05:26 PM
bigdawg460
Feb 17, 2008 12:00 PM
BigDawg54
Computer Chips & Tuners
15
Feb 20, 2004 04:04 PM
BigDawg54
44
Nov 24, 2003 05:14 PM
BigDawg54
Nov 14, 2003 11:10 PM
