Manual swap question
Old Aug 3, 2023 | 03:02 PM
93F2Fitty's Avatar
93F2Fitty
4wd High
Will the pedal assembly and steering column out of a 93 fit into an 86 truck? I have a 93 parts truck that doesn’t have a title and I’m I’m fixing to be in the process of swapping the cab from my 86 2wd onto an 83 4x4 frame but I want to keep the manual transmission
Old Aug 3, 2023 | 04:54 PM
Franklin2's Avatar
Franklin2
It will not bolt in. I would be curious though what the problem is if you want to try it and then write back in and explain what the problem is. But if you do not want to spin your wheels any, get one from a 84-86 truck.
Whitey5.0
Feb 27, 2022 10:03 AM
Cbibb
15
Nov 13, 2021 01:14 PM
evans2332
Jun 19, 2020 07:29 AM
1989FordF250
Mar 22, 2019 02:17 PM
Barman USMC
Feb 24, 2010 03:21 PM
