2021+ F150 Discuss the 2021 Ford F150
Sponsored by: Real Truck
Radiator Louvers Problem
Old Aug 3, 2023 | 11:01 AM
Binkowski's Avatar
Binkowski
Hi all,
Looking for some help. I have a 2021 F150 XL SuperCab 4x4 with the 5.0. The Louvers for the Radiator are stuck in a cycle of opening, pausing but clicking for a second or two and then closing, and clicking for a second or two. I have tried to look for a harness or connection to the louvers that I might be able to disconnect...since it's a heat wave of 107 here in Dallas, but I can't seem to find anything since the louvers are buried behind the grill and in front of the radiator. Any ideas? Any idea where the temp sensor for the louvers would be? Imagine something must tell it to close and open. Truck still under warranty, but in the meantime I'd like a simple "fix". Any chance disconnecting the battery for a while would make the 'system' re-boot and change something?
Let me know if you have any ideas. Cheers.
Old Aug 3, 2023 | 01:33 PM
Bluegrass 7's Avatar
Bluegrass 7
At ignition on before cranking, I don't think temperature has control of the shutters.
The powerup does a full close and open diagnostic and calibration test.
If there is a failure, a code is set.
Beyond this I don't know what you can do.
The fuse lists don't Id many specific circuits as there are a lot of them to list that are combined
Maybe call a dealer service and ask if they can tell you what power source is to help until you get it to service.
Good luck.
Old Aug 13, 2023 | 12:03 AM
BroncoOBX's Avatar
BroncoOBX
1st Gear
Louvers stuck closed -over heating oil
Originally Posted by Binkowski
Hi all,
I’m traveling out west from Florida. The temperatures have been pretty high. My oil temp was abnormally high and the check engine light came on. My Ford app showed 4 or 5 error codes. Everything from overheating, sensor malfunction, louvers malfunction. Sure enough the louvers closed, would not cycle with the ignition. It seemed to be the overheating problem. The Ford dealer could not help me on a Saturday. They only had oil and lube guy there. I texted my Ford Service man in Florida and he told me it was a common problem in Fords. He said I had to open the louvers and disconnect it. Fortunately my son was with me who is an
Bronco 6G Louvers wiring harness
excellent mechanic. He found out the wiring harness is located behind the headlight drivers side. On the side of the road in Union Town Washington we pulled the grill and the headlight assembly. He opened the louvers and disconnected it. Louvers stayed open, Bronco runs cooler in the mountains at highway speeds. I’ll get it into a Ford Dealership to get it fixed but it was a good temporary fix. Somehow aerodynamics and better mpg on something that is as aero as a brick isn’t worth the hassle when the louvers malfunction.
Last edited by BroncoOBX; Aug 13, 2023 at 12:09 AM. Reason: To show it was an on the roadside repair
Old Aug 13, 2023 | 11:38 AM
Binkowski's Avatar
Binkowski
I appreciate the lead on where the plug is. I will explore some more while I wait for an appointment. Cheers.
primer85f150
Jul 3, 2011 08:27 AM
XBAJBUSX
Nov 30, 2010 06:41 AM
RedTaurus94
18
Oct 7, 2004 03:32 PM
SadButTrue
1983 - 2012 Ranger & B-Series
May 1, 2000 01:54 PM
SadButTrue
Apr 30, 2000 04:43 PM
