Oil from tail pipe
Old Jul 31, 2023 | 09:24 AM
just another truck's Avatar
just another truck
Oil from tail pipe
Good Morning all,
so I may corrupted both my boys, they both have purchased 7.3’s. My oldest has a 97 that was sold to him for 500 not running. And has been a blast to trouble shoot. Everything from the IDM was stolen out of it, to needing a PCM. Then old fuel.
we have her running now, but we are pouring oil out of the tail pipe. My first thought was injector o rings, but this did not solve our problem, any thoughts??
Old Jul 31, 2023 | 10:12 AM
knottyrope's Avatar
knottyrope
if you have good compression, it will burn oil as fuel, turbo seals are shot most likely or an injector is leaking by which can cause hydro lock
is it smokey when first running? and firing on all 8?
Old Jul 31, 2023 | 10:13 AM
z31freakify's Avatar
z31freakify
Most likely turbo oil seals, time for a rebuild or replacement. But first make sure it's not residual oil from when you did injector O rings, takes at least 50+ mile of running it hard to burn all the oil out the exhaust.
Old Jul 31, 2023 | 12:36 PM
just another truck
we pulled the turbo and found oil coming up the up pipe passenger side? I am thinking I am going to pull the valve covers, pull the glow plugs, and find which spews oil while cranking over. Then replace that injector.
Old Jul 31, 2023 | 12:37 PM
just another truck
I have done the injector seals on my 99, and as you said, she ran blue for a while. This is oil coming out. Lol
Old Jul 31, 2023 | 02:45 PM
knottyrope's Avatar
knottyrope
I would do a compression test while in there too
Old Aug 1, 2023 | 05:20 AM
just another truck
what would you expect? I ask because if I am leaking through the injector, would I not see 3000lbs of compression?
I get the idea of looking at rings/ heads: head gaskets… but if it is blow through the injector?!
Old Aug 1, 2023 | 07:50 AM
z31freakify
Could be a stuck open injector, allowing fuel to be dumped into the offending cylinder. Pin point which cylinder it is and go from there, and like Knotty said do a compression check as well, could be a more serious problem.
Old Aug 1, 2023 | 10:14 AM
knottyrope's Avatar
knottyrope
if one hole is low in compression, it wont fire and just leave a fuel trail
Old Aug 3, 2023 | 06:57 AM
just another truck
My issue is not fuel, but oil,
Old Aug 3, 2023 | 08:29 AM
knottyrope's Avatar
knottyrope
i would suspect a piston issue if its just oil
kimberlin1961
Feb 19, 2023 01:27 AM
rc.chris
Sep 23, 2015 09:09 PM
brkncly
6.4L Power Stroke Diesel
Oct 30, 2012 01:55 AM
strokin'_tatsch
19
Oct 6, 2009 08:20 AM
