Engine not starting from key after trans install
Old Jul 29, 2023 | 06:17 PM
arc_jpiv's Avatar
arc_jpiv
Hey y'all,
Just got done installing a ZF-5 in my '87 F250. Go to crank it to check it all out and, nothing. Glow plugs click, gauges work, lights work, so I know I have power. Thought to myself, maybe its the clutch safety switch. Threw a fuse in the connector to bypass it, still nothing; fuse stayed intact. Ok, maybe its the solenoid, but I don't here it clicking. I jump the ignition from the solenoid and she starts right up.
Any ideas what it could be?
Thanks!
Old Jul 30, 2023 | 12:42 AM
Prototypemech's Avatar
Prototypemech
Put a test light on your clutch safety switch and see if you have power on it when you try to crank the engine.
Old Jul 30, 2023 | 06:53 AM
tjc transport's Avatar
tjc transport
i ain't rite
did you convert from auto trans? if so, you need to connect clutch switch to the wires that went to the C6 Neutral safety switch.
Old Jul 30, 2023 | 10:53 AM
arc_jpiv's Avatar
arc_jpiv
No, went from 4 speed to 5 speed.
Old Jul 30, 2023 | 11:49 AM
tjc transport
i ain't rite
ok. next step. crawl under the dash and look at the ignition switch on top of the column, about above the brake pedal. it has to be tight between metal and plastic parts.:
with age, they separate and cause all kinds of ignition issues, especially no start.
also, there is the ignition actuator in top of the column behind the steering wheel. when they break 99% of the time it is in the no start position.
when turning key to start, you should feel some resistance and it should spring back to run when released.
if it does not, than the actuator is most likely broken.
Tparks247
Jun 29, 2022 02:32 PM
2manygoats
Oct 28, 2017 08:55 PM
PioneerODR
Jan 18, 2012 03:39 AM
Atwiss
Jul 9, 2010 07:53 PM
FTE Ken
2004 - 2008 F150
May 8, 2007 08:06 PM
