Asphalt Paving
Old Jul 29, 2023 | 02:54 PM
sky Cowboy's Avatar
sky Cowboy
Asphalt Paving
I'm not looking for an exact cost, just a guess, to pave 50' wide by 2400' long.
I'll do the prep for the area, just want it paved.
If anyone has a guess, please post.
Old Jul 29, 2023 | 03:26 PM
85e150's Avatar
85e150
US numbers, your costs will be different...
https://www.homeserve.com/en-us/blog...ark%20estimate.
BC numbers:
https://www.thebestvancouver.com/bes...0per%20project.
Are you going to do a compacted gravel/fines base?
https://store.lyngsogarden.com/produ...-rock-145.html
Old Jul 29, 2023 | 04:02 PM
tjc transport's Avatar
tjc transport
i ain't rite
approximately 110 to 120 ton at 4 inches compacted thickness.
for all top, figure around $11,000 for asphalt alone at east coast USA prices of 85 to 90 dollars American per ton for top coat. base coat is less around $75 per ton. i would recommend 3 inches of base, and 2 or 3 inches top.
that is what we do here for parking lots. roads are thicker, 6 inches base and 3 of top. driveways that only see cars get 3 inches top. if heavy pickups are parked on or use the driveway we go 3 base and 3 top.
and remember, the prep work is the most important part. if it is not compacted properly, the asphalt will fall apart very quick.
Old Jul 29, 2023 | 04:17 PM
85e150's Avatar
85e150
50 feet x 2400 feet = 120,000 square feet.
$321,000 to $600,00 Canadian based on the numbers in the Canadian link above.
They do not mention site prep but I'd bet they'd tell you.....
Old Jul 29, 2023 | 04:39 PM
tjc transport
i ain't rite
that price is what contractors charge to put it down.
my price is to buy the asphalt.
Old Jul 29, 2023 | 04:42 PM
85e150's Avatar
85e150
I think OP needs someone to put it down, at least that's the way I read it.
But cost breakdowns and the cost of materials is always good to have when negotiating a job. Those per foot numbers are a looong way apart on this size job so the more info the better for the OP.
Old Jul 29, 2023 | 05:06 PM
yardbird's Avatar
yardbird
Then almost double that price for a decent contractor to put it down, according to distance hauled, which depends if a base is used or not. If this is a driveway used a lot, and you plan to stay ther 20 years or more, put a base down.
Old Jul 29, 2023 | 06:16 PM
Gomerpyle's Avatar
Gomerpyle
I had my driveway done 3 years ago, 140,000 Sq. Ft. $20,000. I already had a good gravel base. Probably makes a big difference where you are located as well.
Old Jul 29, 2023 | 06:32 PM
tjc transport
i ain't rite
like i said, i only quoted price for materials. for me to do that drive, it would be closer to $30,000.
without stone or prep work.
Old Aug 2, 2023 | 03:33 PM
sky Cowboy's Avatar
sky Cowboy
It is all good information.
Yes i need it laid, rolled etc as well.
I can do the runway bed prep, but don't have paving equipment or asphalt plant.
jade79
13
Apr 19, 2011 08:59 PM
79'f150
73
Jan 17, 2005 03:39 PM
jskufan
Feb 18, 2004 09:45 PM
