So i know that the normal ac setting uses fresh air, and max ac recirculates the air. When i switch from normal to max, i dont really notice a difference. After a few minutes of driving on max ac, the air starts to come out of the defrost and i have to switch it to normal ac to get it back to the dash vents. I assume this is vaccume related, but i dont see any broken lines and im not sure where to start
You have a broken white vacuum line on the passenger side of the engine compartment, near the HVAC housing. Theres a vacuum actuator that move the recirculation door. That vacuum line is known the break.
That line appears to be in tact. The servo that it leads to is what switches from outdoor air to recirc air? This truck sat for a while and maybe that servo is locked up. Im going to try and manually apply vaccume to it from another source. I assume it should be very visually apparent when it switches over
Yes you can visually watch that vacuum servo move when selecting Max AC versus regular AC. If that white line is intact the whole length (very rare these days) you could have a cracked HVAC reservoir, on the evaporator/heater core/blower case, or another common issue is a missing check valve for the HVAC system.
so the white line seems intact but has very weak vaccume. I checked it as far as i could, it seems to go into the top of the blower motor area. Are there more servos under the dash?
The white line seemed compromised outside of the loom. I cut back the loom and spliced in a new rubber line from the area where it meets the firewall. The lines under the dash are in absolute perfect condition. I dont see where i could be losing vaccume. I wired the recirc actuator closed manually for now.
