Is it possible to control the eFuel pump start and stop using the PCM? I had Diesel Tech reprogram my PCM for the manual transmission and saw that they also tested the fuel pump signal. In addition I saw there are pins for a fuel pump in the PCM pin out. But I didn’t know if anyone had tried to run efuel with the PCM.
I’m trying to get the pump to only run for a few seconds before starting and then only when the engine is running. I have the truck apart so now is the best time for me to be messing with wiring.
Its normally done by oil pressure. The lift pump on my Duramax will shut off if no oil pressure is seen. Has a separate sensor the threads into the oil filter housing. https://www.kennedydiesel.com/produc...rness-duramax/
