Computer Chips & Tuners
pcm
Old Jul 20, 2023 | 12:40 AM
gto55's Avatar
gto55
4th Gear
pcm
I think my pcm is bad, I checked powers and grounds, when I turn the key on to run the fuel pump doesn't shut off after 2 second, the engine light stays on, I have no communication with the pcm with the scan tool, the engine don't start unless I spray carb cleaner in the intake, once I get it going it runs rough and black smoke comes out of the tail pipe. I change the capacitors in the pcm they were bad, I read on line that maybe the fuel pump driver is shorted in the pcm, I don't know witch one that is in the pcm if somebody know please let me know and how to check it. If any body knows where I can get a good remanufacture one let me know, I heard too many complaints about flagship one, and I don't know about module experts. It's a 1996 ford f250 5.8 xl, EEc-iv ford number on the pcm is F6uF-12A650-NB, calibration 6-76A-R05, It's a 60 pin pcm, I wrote down some of the numbers that are on the drivers on the side of the pcm, 986t04, 644t01, 04s80, 638t01, Thank you for your help.
Listor
Sep 19, 2021 03:32 PM
CREECY Strokin It!
Apr 5, 2011 03:28 PM
Rino Onir
Nov 10, 2007 11:20 AM
roller_steve
27
Dec 1, 2006 02:13 PM
