Sponsored by: Real Truck
Which Trans fluid??
Old Jul 23, 2023 | 01:29 PM
Mike1's Avatar
Mike1
Which Trans fluid??
Hi everybody, my 2003 F350 5.4L 2v 4R100 trans is low, is it ok to use the Super Tech Mercon V or which is the preferred fluid?
Thanks for any input on this.
Old Jul 24, 2023 | 06:28 AM
projectSHO89's Avatar
projectSHO89
Any reputable fluid labeled as Mercon V (or "recommended for") is adequate. There are a number of them including the ST you asked about.
Of course, the better question is if the fluid level is low , 1) was the fluid level checked properly and 2) if confirmed to be low, where did the lost fluid go (assuming it was correct at some time)?
Old Jul 24, 2023 | 08:54 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
I would only use fluid that says MERCON V on it. I will not use a fluid that says recommended for use where XXX is required. Those are weasel words that mean that the fluid manufacturer states that it is OK with them for you to use their fluid. It does NOT mean that it is good for your transmission.
If it says MERCON V on the label then it has a MERCON V license and Ford has confirmed that the fluid meets the MERCON V specification.
I've used SuperTech MERCON V in my 4R100. IT works fine.
Old Jul 24, 2023 | 01:08 PM
Mike1's Avatar
Mike1
Thank you for the replies. I appreciate them.
@projectSHO89
Vehicle fully warmed up on level ground checked in Park while running.
It's been awhile since I checked it, it's been misfiring for awhile so I let it sit until I could get to it. Had to put a new oil tube for the dip stick in it, it rusted off. Then I had to change all the coils plugs and MAF, even though no readers would pull codes. Checking the Trans, the fluid is on the ball of the stick, so it's been at least 6 months since checking it and it was full last time. I was under the truck over the weekend and did not notice and leakage, but not to say one didn't develop...I did not check into the cooler lines at the front though. I'm going to pick up about 4 quarts on the way home, I don't think it will take more than 2. I'll check for leaks again after I warn it up and fill it up.
Old Jul 24, 2023 | 01:49 PM
projectSHO89
Mark's well-qualified opinion is far more conservative than mine regarding licensed vs "recommended" fluids.
Go with whatever makes you most comfortable.
Old Jul 24, 2023 | 03:55 PM
Mike1's Avatar
Mike1
I was looking for the motorcraft brand but nobody in my area is carrying it except Ford. I saw Super Tech mercon v at Walmart then I figured I'd use the Mobil brand but they only had it for import cars so I grabbed the last 2 quarts of Super Tech. I know Mark is the expert that's why I was looking for the Mobile trans fluid after reading about the race he was using it on the 4R100 trans with the oil coolers and fans setup in the bed of the truck...lol innovative for sure.
Old Jul 24, 2023 | 07:55 PM
00t444e's Avatar
00t444e
Supert Tech Mercon Rated ATF is all I have used for years. Never had a problem.
Old Jul 24, 2023 | 08:01 PM
Mark Kovalsky
NOBODY has made a MERCON rated fluid since the specification was obsoleted in 2006. Now all anyone can make is a fluid that they recommend for use where MERCON was specified. It does NOT have a MERCON license because none are available.
Old Jul 24, 2023 | 08:34 PM
00t444e's Avatar
00t444e
That's all right, the transmission fluid doesn't care if it has a license or not.
Old Jul 26, 2023 | 09:02 AM
Mark Kovalsky
But you should care, because without the license how do you know what's in the transmission fluid? Did the manufacturer put Type F in the bottle and say it is for use where MERCON was specified? That's legal. Without a license the fluid can be ANYTHING, you're trusting the company that made it to do the right thing.
Maybe they do and I've just become cynical from working at some of these large corporations where the only thing that counts is making a profit.
Old Jul 26, 2023 | 09:11 AM
00t444e's Avatar
00t444e
You can check it here if you want to.
https://pqia.org/automatic-transmission-fluid/
Old Jul 27, 2023 | 08:37 PM
HRDROKN's Avatar
HRDROKN
The thing is that there are no (not that I am aware of) modern transmissions requiring a Mercon V spec..... the current specs have all exceeded the previous spec. So few (very few) qualify (license) oil for an outdated spec. Recommended or as I see it "backwards compatible" is a spec that generally exceeds the spec for which it is recommended.
Old Jul 27, 2023 | 09:16 PM
Mark Kovalsky
There are still several MERCON V licensed fluids on the market.
Later fluids such as MERCON LV or MERCON SP or *NOT* backward compatible. They will both tear up a MERCON V transmission in short order.
Old Jul 27, 2023 | 11:22 PM
HRDROKN's Avatar
HRDROKN
Agreed, I don't think those specs claim any backwards compatibility.... and I don't think that I was suggesting that those specs were backwards compatible. IMO a backwards compatible spec meets all the minimum requirements and exceeds in the rest... LV doesnt meet the vis and I'm guessing (without looking it up) SP falls short as well.
trike1946
Oct 8, 2021 10:24 PM
Headviking
Aug 13, 2010 05:24 PM
ford owner 249
Aug 1, 2010 04:15 PM
