bubble test for gaskets
AutoZone loans out the kit (pay for it and get your money back at return), and IIRC, the one I got even had a plastic hose. This was it: https://www.autozone.com/test-scan-a...it/1053958_0_0
Would I even need the hose? Couldn't I just plug that gauge into the Milton and watch to see how the pressure changes?
I advised the owner not to drive the truck any further.
Unfortunately, he did not follow the well-intentioned advice.
A few weeks ago I got the truck back with a stuck engine (hydrologged on 2 cylinders).
Since my EGR is blocked, does the VGT affect bubbles? One vid from someone said the VGT releases pressure into the EGR, or not, and makes the bubbles go faster or slower. With no EGR, does disconnecting the VGT do that?
Watching vids, sometimes there's no bubbles. What is the bubble situation supposed to be with good gaskets and no EGR? Maybe no bubbles at all?
For the record, I'm getting no smoke at all. And I have never seen signs of coolant from the degas - does the red ELC still show white when leaking? I thought my delta was high for a new oil cooler the only time I'm driven it up to WOT, but come to find out I was losing an injector at the time from a loose FICM connector. That prolly makes the engine run hotter in this weather. I'm going to drive it tonight after it cools off and see if that changed,
Maybe, rather than mess with the bubble test, I just need to check my coolant pressure before and after getting up to WOT and releasing pressure from the degas. Would that coolant test kit from AutoZone work for that, just using their cap and gauge, not pumping it at all? I see others in the vids adding a T to the smaller degas hose for their gauge.
Make a T-piece in the small hose that goes from the degas bottle to the radiator. Connect a pressure gauge to it (0-20psi).
Warm up the engine and release the pressure from the degas bottle. Run the truck several times with WOT (preferably under load so that it builds up boost pressure).
This is "the moment of truth"
So, if I understand correctly, if the gaskets are good, and with a blocked EGR, it'll should never build to 15psi. And, after letting off the pressure it does build getting up to WOT, and tightening the cap again, it should never build pressure, or certainly not 15psi.
As for the bubble test, if the gaskets are good, blocked EGR, WOT, should there be no bubbles? Or just a small steady stream that doesn't increase under load? Does disconnecting the VGT do anything to the bubbles with a blocked EGr?
So, I started the truck, leaving those few pounds I'd pumped in the system. I had cars behind me in the driveway, so I just idled there. It was in the 180s when I decided to rev the engine to hurry the thermostat. Kept my foot on the brake and put it in reverse while revving for less than a minute, maybe 1500-2000 rpm. Jumped out to look at the gauge and it really hadn't moved. However, I moved it too much and it blew the stopper out of the hole.
No biggie, I was almost ready to let the pressure off anyway. So, I got the stopper back in and let it Idle a little bit more. When I next checked, the EOT/ECT temps had flipped, so I figured the TS opened up and jumped back it to put some load on it. Foot on brake in reverse, I revved it for another minute. Checked, nothing, revved it some more. Finally got it to register 3-4psi, but that seemed like as far as it was going.
I'm just not sure that stopper was sealed good. Not sure what the gauge and T fittings cost, Harbor Freight closed early tonight before I got there. I'll try again tomorrow and actually get it out on the street.
Other note - I never really saw the boost gauge on my dash moving while revving with foot on brake, and forget which two PIDs calculate that. IIRC, there are multiple MAP PIDs and I couldn't tell which was which. Not getting any codes on the truck with TP and FS.
That said, I did get the truck up to WOT, the thermostat opened, but I never saw over 5psi of pressure. Thinking about all the threads I've read on this issue, I can't recall any saying what the pressure should be when everything is fine. Does 5psi sound whack, or is that normal?
Question: while trying to generate boost by revving the engine with it in reverse, after a minute, I saw wispy black smoke coming from under the hood, right over the turbo/downpipe area. Would that be an indication of that bad pipe connection, or is it coming from the turbo itself? I've never actually had this turbo work properly yet, that I can confirm. The other time I drove, I didn't have that exhaust connected and everything was so loud, I couldn't tell. Again, these big trucks and my buses don't drive/perform like 250s. The difference between running good and bad is not as easy to distinguish - these big trucks just drive slow and strain all the time. Maybe wispy black smoke is normal when forcing the engine like that, IDK.
Here's a twist - I also get a P0500 code now. I'm going to clear it and see if it comes back on the next test. On this drive, I had to push the pedal to the floor hard to finally get a downshift (not sure of the gears, driving ~35mph city street). Felt like it downshifted two or three gears, maybe from 6th to 3rd. It'd jump to 3000rpm and scream (not sure if there was boost, happened too fast, I forgot to look). This big heavy truck doesn't like the bumpy city streets and my headache rack is still broke, so I'd back off as soon as it downshifted like that. I wanted to get some happy middle gear, but no luck.
Apologies, I didn't expect all these boost issues, I had no codes idling in the driveway when I took off, and wasn't prepared to monitor or test all this other stuff. I'm wondering if the P0500 triggered because of that aggressive driving and downshifting. Note - this truck hadn't been driven for several years, and has only made one drive over a few miles since I've started working on it. And, I've disconnected the batteries for several days since that trip. I'm wondering if the tranny just needs to relearn and the lack of boost is messing with that process combined with my crazy driving to set that code. I didn't know the code had set and didn't look at the speedo while I was driving. Maybe since the code hadn't actually triggered a CEL, it didn't affect the speedo.
So, anyway, I'm thinking I'll focus on the turbo issue first and see what happens with the P0500.
I'm hoping that low pressure wasn't a fluke. I still have no reason to suspect gaskets, just want to be sure before spending more money on this.
