Sponsored by: Real Truck
Trailer Socket
Old Jul 22, 2023 | 04:55 PM
Dah911's Avatar
Dah911
Trailering
Trailer Socket
Hello Everyone,
I'm hoping someone here can point me in the right direction for my problem I'm having. I have a 2006 E350 work van and is used hauling my dumpster trailer when needed. I recently plugged in trailer and while checking if all lights working, they all shut off do to a short.
Since than rewired trailer and the issue I'm having is with van trailer 7 socket connector that was installed on van when purchased over 15 years ago and worked flawlessly.
My problem is with Right turn/stop and Left turn/stop. Both wires read a little under 12 volts but when adding a 1 led light to either wire (green) or (yellow) wire it drops to 4 volts and dimly lights. From original from trailer short it did blow the tow turn single fuse (26) that I replaced and also replaced the Tow trailer left and right relay with no help. My first thought was ground and traced back to connection on chassis and cleaned. Just to avoid any confusion I'm working from plug back... I eliminated the trailer.
I would appreciate if someone could suggest something I might have missed. I am thinking I may have to just run 2 new wires, any suggestions on how far back to go and where would be a great help.
Thanks,
Dan
Old Jul 22, 2023 | 07:56 PM
Old and soft's Avatar
Old and soft
In my line of work, a voltage drop like that indicates a bad wire or connection somewhere.
Old Jul 22, 2023 | 08:43 PM
Dah911's Avatar
Dah911
Trailering
Hi and thanks for your reply, I totally agree. Oddly though these are to separate wires each with their own relay giving same voltage drop, What I'm hoping to accomplish is to eliminate theses' wires at the feed and run new so can save hours/days/weeks tracing through harness. Little experience
reading electrical diagrams even if found 1 on internet.
Thanks,
Dan
TangoTempest
All Things Towing
Mar 22, 2022 06:07 PM
Rod Bensken
6.7L Power Stroke Diesel
Aug 6, 2013 12:41 PM
wedge88
Sep 24, 2012 07:42 PM
Trek93023
Electrical Systems/Wiring
Sep 22, 2006 04:58 PM
alpine7572
1978 - 1996 Big Bronco
Feb 10, 2003 08:20 AM
