Receiver Bolts
Old Jul 20, 2023 | 04:27 PM
Jopa127's Avatar
Jopa127
6th Gear
Receiver Bolts
New here but did a lot of reading on replacing my hitch receiver. Thank you to those who have shared their experiences. The factory one rusted out and bent while I was moving my camper around the storage yard. Got really lucky.
The truck is a 2005 Excursion V10. When reading I saw that the only difference between the years was the bolt size. Earlier had m14 and later had M18. I got an excellent condition hitch off a low mileage 2000 excursion. Receiver looks like it was never used. It's free so it's for me. I know, I know....used??!?!?! Why not new??? But for the free price I couldn't pass it up.
Problem I had was once removing the unit from my 2005, I realized the 2000 unit also has smaller holes, so the M18 bolts did not fit. So I was left with the dilemma of drilling the hole out or just use m14 hardware. Dealer wants an arm and a leg for the bolts and nuts. The nuts come in pairs on a plate at 19$ a piece and the bolts are 15$ a piece.
I found a place online called Belmetric. They had m14x63mm bolts, m14 nuts and m14 fender washers. All grade 10.9. The nuts are flared locking nuts. It's 102$ for all the hardware shipped 2 day FedEx.
Has anyone else ordered from here? Where else can you source this hardware?
Joe
PS- The hitch im installing has a sticker on it that boasts the tounge weight of 1k and max tow weight of 10k.
Old Jul 20, 2023 | 05:57 PM
Dweber85rc's Avatar
Dweber85rc
You can safely drill out the holes to the larger bolt size and be just fine.
Old Jul 20, 2023 | 06:15 PM
Jopa127's Avatar
Jopa127
6th Gear
Thanks for the fast response! Any suggestions on what kinda bits to use? I have some black carbide but not sure if they are large enough.
Old Jul 20, 2023 | 09:54 PM
Antonm23's Avatar
Antonm23
Drill out the receiver to match the hole size in the frame, then just go down to your local Lowes / Home Depot/ Tractor Supply and get some grade 8 bolts , nuts and washers (grade 8 hardware is usually gold in color, but not always).
Doesn’t need to be that complicated.
Old Jul 20, 2023 | 09:58 PM
Jopa127's Avatar
Jopa127
6th Gear
Couldn't find any grade 8 bolts long enough. I need at least 2.5" or 63mm. That's why I ordered them. Longest ones I found were 2". Grade 8 is ok? I thought I read grade 10.9 was used from the factory.
Old Jul 21, 2023 | 08:37 AM
Smoothwater's Avatar
Smoothwater
I'd just make the hole a little larger with an air grinder or stepped bit and repaint. Good to go
Old Jul 21, 2023 | 09:41 AM
Antonm23's Avatar
Antonm23
10.9 is a metric rating whereas grade 8 is an SAE rating. The two are virtually identical in strength. Think of 10.9 as a 13mm socket and grade 8 as a 1/2-inch socket, pretty much the same, not exactly the same, but pretty much.
So yes, grade 8 hardware is just fine as a replacement for 10.9 hardware.
Post edit: Heres a link to a couple of business explaining the bolt grading if you don't wanna believe some random internet stranger.
https://www.fastenermart.com/understanding-fastener-grades-and-classes.html
https://www.aatprod.com/understanding-the-difference-between-inch-metric-strength-grades-for-fasteners/
lleibeck
Oct 19, 2022 08:57 AM
5851a
All Things Towing
Jul 14, 2016 07:50 AM
Oilfield Trash
Mar 19, 2016 11:58 PM
System
Mar 13, 2010 02:54 PM
lawnspecialties
Feb 15, 2008 09:21 AM
