Hitch Bolts??
Old Sep 25, 2022 | 10:10 AM
lleibeck's Avatar
lleibeck
4wd Low
Hitch Bolts??
Does anyone know what these two bolts are for, on the stock hitch?
I have a 2022 F350 and would like to use these bolts to mount a light bracket.
Thank you
Old Sep 25, 2022 | 12:11 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
Don't see any reason why you couldn't use them, they already look like they have separate washers, and they aren't big enough to be anything highly stressed.
Old Sep 25, 2022 | 01:04 PM
4wd6.7L's Avatar
4wd6.7L
Those 2 bolts are bumper mounting bolts.
Old Sep 25, 2022 | 01:57 PM
lleibeck's Avatar
lleibeck
4wd Low
Thank you,
Do you know if the hitch bar is threaded to receive those bolts?
Hate to unscrew one and hear a nut fall off, looks tricky to get the nut back in place if so.
Old Sep 25, 2022 | 02:27 PM
4wd6.7L's Avatar
4wd6.7L
Originally Posted by lleibeck
Thank you,
Yes, the threads are in the hitch bar, no loose nuts. I believe they are pretty low torque too, like 20 ftlb.
Old Sep 25, 2022 | 02:54 PM
bigwin56f100's Avatar
bigwin56f100
Thank you
pics of the light bracket please
Old Sep 25, 2022 | 05:55 PM
lleibeck's Avatar
lleibeck
4wd Low
When they arrive I will include pics. Depending on the storm is when delivery is expected
this is what I ordered https://www.f150leds.com/collections...32346949255305
Old Sep 25, 2022 | 08:24 PM
cnote72's Avatar
cnote72
Did you order them with the upfitter harness option? Stay safe down there. Heading to LA in a few weeks, hopefully no hurricane action while we are there.
Old Sep 25, 2022 | 08:58 PM
lleibeck's Avatar
lleibeck
4wd Low
Did not see that as an option
did order with the long cable and switch. -lan to cut their switch off and wire to upfitter
Old Sep 25, 2022 | 09:38 PM
rjacobs's Avatar
rjacobs
Just a thought... If you put those lights there, your hitch becomes completely unusable because you wont be able to put a pin through the hole. you also might block access to the safety chain holes(as useless as they already are LOL).
Like I said, just a thought, but I dont know what your plan is, maybe you are going to make a bracket that mounts them further outboard.
Old Sep 25, 2022 | 09:58 PM
chadstickpoindexter's Avatar
chadstickpoindexter
Good points. I picked up some inexpensive LED lights from Tractor Supply and mounted them using a bolt under the bumper. It spread the light out more and doesn’t interfere with the hitch or chains at all. I opted for round ones some they wouldn’t look crooked when I bolted them up too… lol. Maybe the OP could look at using these same bolts.
Old Sep 25, 2022 | 10:46 PM
lleibeck's Avatar
lleibeck
4wd Low
My challenge is I have the kick down step under the bumper on the left side. Won’t really have a firm plan until the lights arrive
Old Sep 25, 2022 | 10:51 PM
lleibeck's Avatar
lleibeck
4wd Low
Thinking of making a plat out of aluminum to mount the lights to then mount the plate to the truck via the bumper bolts
Old Oct 19, 2022 | 08:57 AM
lleibeck's Avatar
lleibeck
4wd Low
Lights installed
I decided to make a smaller bracket, flat bar aluminum with two holes. One for the light the other for a bumper bolt on the bottom of bumper.
Before anyone says my lights a crooked, I call them aligned. I have to back this truck down a drive very close to a curved retaining wall every time I drive the truck. So I have aimed the lights to be sure wall and curve are lit up.
I did use the upfitter kit from F150LED. Hooked up to upfitter 1. Kit includes a relay to connect to upfitter and a power cable to battery
ford_murph
Jun 27, 2020 02:46 AM
5851a
All Things Towing
Jul 14, 2016 07:50 AM
Oilfield Trash
Mar 19, 2016 11:58 PM
System
Mar 13, 2010 02:54 PM
lawnspecialties
Feb 15, 2008 09:21 AM
