Hitch
Old Jul 8, 2016 | 04:46 PM
5851a's Avatar
5851a
Hitch
Have a WD hitch made by Robin (Looks like Reese knock off), used it for 8 years and the other day I noticed it has play between the head and shank part. It does not look like there is anyway to tighten the through bolts enough to take the side to side gap out. Don't remember any shims being in there when I raised it up for this truck. Should I take it to a big truck shop that could but some more torque on the bolts?
Old Jul 9, 2016 | 08:26 AM
wrvond's Avatar
wrvond
The play is not a good thing, but over torquing the bolts could be even worse. There is a point where things need to be replaced.
Old Jul 9, 2016 | 09:08 AM
RV_Tech's Avatar
RV_Tech
Agreed. How often does anyone ever have to tighten the bolts on their hitch? I am guessing almost never. Does this represent a change or has it always just been a loose fit?
Steve
Old Jul 9, 2016 | 11:36 AM
5851a's Avatar
5851a
I thought it was tight when I changed the height for this truck. I'll try to tighten it again. Didn't notice till we were at campground and took hitch off (No tools of this size). It does have Nylock bolts and I did reuse them when the height was changed. If it will tighten more I'll get some new bolts, if it doesn't I'm going to get a new Reese I think.
Old Jul 9, 2016 | 07:57 PM
HRTKD's Avatar
HRTKD
Steve
My toy hauler came with the WDH. When I configured it for my truck I found that the ball wasn't tight. It's handy to own a set of big **** wrenches.
Old Jul 11, 2016 | 02:36 PM
wrvond's Avatar
wrvond
Steve
Along those same lines - my Reese calls for 200 lb.-ft. on the 3/4" nuts and the hitch ball nut. How many people actually have a torque wrench that goes to 250 lbs.?
Old Jul 11, 2016 | 02:59 PM
HRTKD's Avatar
HRTKD
I had to go look but one of my torque wrenches does go up to 250 ft/lbs.
Old Jul 13, 2016 | 05:34 PM
5851a's Avatar
5851a
Checked bolts tonight and both through bolts were hardly tight and ball is slightly loose too. Going to get some new bolts tomorrow, reassemble and take it to a implement dealer that should have some big but torque wrenches.
Old Jul 13, 2016 | 06:21 PM
HRTKD's Avatar
HRTKD
Maybe throw on some Blue Loctite?
Old Jul 14, 2016 | 07:50 AM
Chuck's First Ford's Avatar
Chuck's First Ford
last year I purchased a New Pro WDH and all the bolts came with Loctite and lock washers.
191124x7
All Things Towing
15
Apr 16, 2017 02:51 PM
Oilfield Trash
Mar 19, 2016 11:58 PM
Inline6xl
Jul 16, 2014 06:50 PM
System
Mar 13, 2010 02:54 PM
lawnspecialties
Feb 15, 2008 09:21 AM
