Guide on replacing rear Leaf spring bump stops?
Old Jul 19, 2023 | 09:55 AM
MRI503's Avatar
MRI503
1st Gear
Hi,
(2003 Excursion with 7.3L)
Been doing some searching to see if I could find this without creating my own post - but can't seem to find anything that outlines how to replace the rear bump stops that are mounted on the read leaf springs? It would seem the rear end may need to be lifted off the ground to get enough clearance to install the new ones (and in my case, only remove the one that's still there)...
Thanks!
Old Jul 19, 2023 | 12:31 PM
Dweber85rc's Avatar
Dweber85rc
Correct. You must lift it up by the frame to release tension on the spring enough to get the new ones in.
Rogers F100
Sep 28, 2015 04:23 PM
TruckNorris
Mar 20, 2012 12:46 PM
btdrygulch
1983 - 2012 Ranger & B-Series
18
Jul 4, 2011 10:14 PM
808dsl
Hawaii Chapter
Jun 8, 2009 01:22 PM
