Sponsored by: Real Truck
What tire size???
Old Jul 18, 2023 | 07:27 PM
Mikethetrucker's Avatar
Mikethetrucker
What tire size???
2013 F-250 4x4 CrewCab 6.7l. Stock ride height.
My truck currently has 20" Fuel Assault wheels with 305/55R20 Toyo tires.
Getting new tires and wheels because the tires are ready and I hate 20's.
Wheels will probably be 18in Fuel Vectors or Icon Rebound HD. The tires will be BFG All Terrain's for sure, but I'm not sure what size. Need help deciding.
Do I go with the factory size 275/70R18 so I can utilize the spare or do I step up to a 295/70R18 and lose what little fuel economy I have and probably have to trim the inner fenders a bit (current setup rubs at full lock, these are bigger). I could probably still use the spare in extreme emergencies. The 295's are also $100 more.
The choice seems obvious, but damn, the bigger tires sure would look cooler...
Does anybody run the 295's? What kind of mileage are you getting? Did you have to trim or level/lift to fit? Pics?
Also, opinions on the Icons vs. the Fuel wheels. I had the same Fuels on my 150 and liked them well enough.
p.s. don't tell my wife about this conversation...
Old Jul 18, 2023 | 09:35 PM
Lance Helmert's Avatar
Lance Helmert
Check customoffsets.com , they have pictures and specs of what people are running and how they fit.
Old Jul 19, 2023 | 07:50 AM
redford's Avatar
redford
FTE Leadership Emeritus
You might want to research the choice of BFG tires. I used to be a huge fan, owning multiple sets of highway and AT tires. I loved the TA K02s, but reports on all BFG tires just the past few years seem to indicate a slipping in quality. I see a lot of recent reports about BFG tires being defective and being very difficult to balance.
Old Jul 19, 2023 | 08:28 AM
BlackBeest's Avatar
BlackBeest
295/65/18 is same rolling diameter as 275/70/18, fyi, if you don't want to level the frontend
Why don't you sit down in front of one of those tire size calculators and plug in some options.
If you're set on 18's, I'd put a front leveling kit on, and run some like 315/60/18's. Those are also the same rolling diameter as stock, so no concerns about spare (but honestly, how often do you really roll on the spare?)
Old Jul 19, 2023 | 08:40 AM
Akley88's Avatar
Akley88
the 295/70r18 shouldnt be an issue without a lift if the right wheel offset is used. its about 34.3" overall diameter with a width of 11.5". the largest oem tire was a 275/60r20 which is about 34.1" and 10.9" sectional width. i only rubbed my oem mud flap on off angle turns with a 18x9 +18 with a 12.5" wide tire and that was probably more due to them being 37s. as far as a spare ive seen some guys fit 37s in the stock spare location.
Old Jul 21, 2023 | 10:52 PM
7636074460's Avatar
7636074460
As a Tire technician and sales in the past, I can say that the fuel wheels are garbage (at least at the price they want). I've seen countless 'welders' shatter fuel wheels, and then you can't hardly find a matching replacement as they change their designs too often. The hub caps are all junk, too. I prefer pro-comp, if you're sill looking. I haven't seen your other choice.
The 2757018 is an excellent choice as you can find one anywhere being it is a factory option on Ford and Dodge for years. It is also a great performing tire in most conditions, and every major brand has an offering to choose from. I bought the k02 as soon as they were released. I am not a repeat customer. They can really change the look of a vehicle, but they are Nothing like the original KO! My new Jeep Rubicon came with KO2's, and they've done well on that for 37000 miles. I use treadwright now. They are remolded (USA) and I have put the test to them, I ain't a city driver and i'm doing something like 30k each year now. I could try to sway you to a hankook ATM since you didn't do well in the toyo, and save you money. I used to really love the coopers, but since they changed the design around 2016ish (cant remember when that rolled because it took two years to deploy all sizes) I didn't get to see them ran long-term personally. If their cheaper than the hankook is, that would be my choice. Cooper/Hankook ran neck-n-neck in my book. As far as balancing, every once in a while you do get a heavy spot. If that happens and you're working with a good dealer they can actually warranty that tire back before they even mount it to your truck. It is called Out Of Round Condition. Not typically found in A/T's, moreso M/T.
295's are a 'specialty size'. If you travel, you're asking for trouble. If that's what you choose, buy six of them or keep one of your old 20" w/t combo's on hand. I don't think you'll have a fun time loading a 295 into your spare rack. This size also costs more, just because. Not as many of the 'major' names build in this size, either so you are stuck with 'magazine ad' brands. They usually take a pound of sticky weights, on a good day. You'll have to invest 1000 bucks into hub balancing rings (one-time purchase, though. )
I think i might miss working in this field
Robert Parmenter
Feb 27, 2019 12:37 AM
iceman320
Apr 5, 2009 04:42 PM
Drake12
Jun 9, 2004 11:25 AM
