Sponsored by: Real Truck
Tire size
Old Feb 25, 2019 | 07:38 PM
Robert Parmenter's Avatar
Robert Parmenter
Tire size
Recently got 2001 f350 4x4 7.3. Drive 57 miles to work all highway. How tall of tires will fit without rubbing? Thinking of 315 85 16
Old Feb 26, 2019 | 01:12 PM
brian42's Avatar
brian42
Veteran: Navy
Stock height or lifted? OEM or aftermarket wheels?
OEM wheels are 16x7" with a +6mm offset.
I have Ultra Type 164 wheels that are 16x8" with a -6mm offset (basically an extra 1/2" on each side). I have 285/75-16 BFG AT KO2 tires and can go full lock in either direction without rubbing...but not by much.
I might be able to clear a little larger without rubbing the springs but anything larger (with full tread depth) would most likely rub on the fender liner.
There's no way I could fit 315/85-16 tires on my truck without rubbing with the wheels I have. That tire is 4" taller and more than 1" wider than what I have.
Once you venture into aftermarket wheels/spacers then that opens up more options for tire size even at stock height.
Old Feb 26, 2019 | 05:19 PM
'01V10's Avatar
'01V10
I have an '01 f350 (6.8) and 285/75-16 Mickey thompson ATZp3 on the stock wheels. I can make them touch the leaves if I crank it hard enough. I wouldn't want to go any bigger. I used to have the same basic truck, with the same wheels and 285 firestone A/Ts and it didn't rub at all, but they were much less aggressive tires. Point being, I wouldn't go wider than 285 unless you have the proper backspacing to make it work. As far as height, I believe my front leaves are a little tired and saggy, but with the way mine sits I don't think I'd want to go much taller either.
Old Feb 27, 2019 | 12:33 AM
Robert Parmenter
truck is all original
Old Feb 27, 2019 | 12:37 AM
Robert Parmenter
truck is all original height and wheels
ahiaring
Oct 9, 2019 06:36 PM
Jon Miller
Jul 31, 2012 08:48 AM
kris_tx
Nov 21, 2005 07:29 PM
jasonlasvegas
Jul 5, 2004 07:35 AM
mtbjedi
1983 - 2012 Ranger & B-Series
Apr 29, 2004 11:14 PM
