AC Blower Motor
Old Jul 16, 2023 | 09:45 AM
molina505's Avatar
molina505
4wd Low
AC Blower Motor
I own a 2002 F350 7.3 and have recently come across information suggesting that grounding the blower motor directly to the battery could enhance its airflow capabilities. I'm curious if anyone has knowledge or experience regarding this matter. If it indeed works, could someone provide guidance on how to properly ground it to the battery? Thank you.
Old Jul 16, 2023 | 08:30 PM
knottyrope's Avatar
knottyrope
Yes it can improve the flow a little. . Run a wire from battery neg to the neg of the blower.
Old Jul 16, 2023 | 09:56 PM
molina505's Avatar
molina505
4wd Low
Would I just tap into the current negative or just run the one straight to the battery? Thank you.
Old Jul 16, 2023 | 10:19 PM
Hit Man X's Avatar
Hit Man X
I would not waste my time. Maybe your resistor is junk.
Clean the evap if you are experiencing low flow from the vents. One never knows what crap sucks up into it after 20 years.
Old Jul 17, 2023 | 05:39 AM
molina505's Avatar
molina505
4wd Low
I installed a new resistor, evap and fan. I’m not sure why my air flow is so low.
Old Jul 17, 2023 | 08:02 AM
Hit Man X's Avatar
Hit Man X
Fan blade could be on backwards, seen it before.
Old Jul 17, 2023 | 12:59 PM
pern21db's Avatar
pern21db
Have you tested the blower on and off the vehicle? I wonder if the vents are clogged.
Old Jul 17, 2023 | 01:18 PM
knottyrope's Avatar
knottyrope
did you replace the blower motor or just the fan?
My fan was fine but the motor speed was low, new one fixed it
while blower was removed i used a garden hose and some detergent to wash out the whole insides that were covered in mucky mouse nest stuff
after it was blowing so much, i dont use speed higher than 2 now even on hot days unless its been sitting in the sun all day
Old Jul 17, 2023 | 06:33 PM
jstihl's Avatar
jstihl
I found that when my blower motor quit I replaced it with a aftermarket parts store brand since I was in a pinch. It was noticeably blowing less air so I eventually installed a motorcraft blower motor and it was back up to par.
Hyakkimaru
40
Dec 16, 2021 11:40 AM
Grantmh6.4
Oct 11, 2018 07:37 PM
Skyline Drive
Jan 30, 2015 06:50 PM
fixit5561
Jul 27, 2010 01:59 PM
86ford
Nov 9, 2002 10:59 PM
