7.3 ICP Comparison Experiment Assistance
Old Jul 10, 2023 | 08:55 PM
Higgins213's Avatar
Higgins213
Hi y'all!
So here's what's on my mind... over the next week or so I am going to be making a comparison/performance video for YouTube (similar to Project Farm) with the 7.3 Powerstroke's ICP sensor as the subject!
• I am curious regarding just how different in quality there is between the 170 dollar MotorCraft one that I purchased from RiffRaff all the way down to one that I got for 10 bucks off ebay. I have 4 others with various costs for a total of 6 sensors.
Basically, I was hoping that some of you might be able to help me with exactly what types of testing/what numbers I should be comparing when testing these sensors. I have ForScan and was planning on recording numbers on start up, while idiling, as well as various points of acceleration. Also was planning on recording how truck is running on the surface level (how it sounds, smoothness of idle, etc). Was also going to notate the effects each sensor had on the IPR's duty cycles.
I am extremely curious to see just how much (or how little) difference there is between a 10 dollar sensor and one that costs x17 as much.
Is there anything else that I should perform/keep track of? Temperatures/pressures/fuel mileage? I will include you as an Executive Producer in the credits when I put video on YouTube.
Old Jul 10, 2023 | 10:03 PM
John in OkieLand's Avatar
John in OkieLand
me too,
I have one of those "Ford Amazon" sensors from Amazon in the glove box, got it a couple days after i bought the truck up in Montana, and had almost 3,000 miles of desert highways to travel before I got home...
never needed it, nor has the engine needed anything period.
runs smooth as butter.
Old Jul 10, 2023 | 10:36 PM
duck fan's Avatar
duck fan
Because racetruck
I would say without digging deeper simply watching what values it gives on Forscan isn’t enough for any conclusive information or comparison. Problems forum members have experienced over the years range from undersized connections pins, incorrectly threaded body, passing oil through the sensor or completely failing with in hundreds of miles, and then of course inaccurate voltage readings among other things. Without tearing sensors apart, knowing how to examine the circuits, and maybe watching the signals with a scope I can’t imagine it showing much info. Over the last 20 years forum members have demonstrated through trial and error why aftermarket sensors just don’t work over the long haul on these trucks. The most eventful that comes to mind is about 10 years ago when many purchased ICP sensors off eBay for a great price only to find out within a couple hundred miles they would blow out of the head coating their engine in oil and leaving you on the side of the road.
Old Jul 10, 2023 | 11:08 PM
Tpayne621's Avatar
Tpayne621
I'm sure 95% of them will "work" but for how long is the real question. Longevity.
Old Jul 11, 2023 | 01:10 AM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
I thought about doing just such an experiment, but never gave it a go. My plan was to make a manifold so all sensors could be mounted simultaneously. Then you just switch the connector among the ICPs and run it thru the same prescribed paces. Swapping ICPs would get tedious, and more time between tests introduces variables. Better yet would be a switched connector between the ICPs and the harness where you could have all the ICPs connected simultaneously and just switch between the sources on the fly.
Pic below shows the voltage output of the ICP sensor vs measured psi. I took it from Whitemw's excellent 7.3 Quick Reference guide which is linked below.
On edit: this would only test electronic function of the ICP. As Peter mentioned all the other manufacturing factors such as heat tolerance or oil intrusion would not be addressed.
Old Jul 11, 2023 | 05:44 AM
FordTruckNoob's Avatar
FordTruckNoob
Perhaps all ICP sensors mounted on a test manifold subjected to the same pressure pulses then see which one blows first would be a more illustrative video. You will encounter no end of discussion over what that pressure profile should look like (peak pressure, ranp rate, pulse duration, etc etc) I am sure.
Old Jul 11, 2023 | 06:49 AM
helifixer's Avatar
helifixer
Years ago a member had a random dying problem, finally narrowed it down to driving past the front of a store with an automatic door opener and when he was backing his rv and would talk to his wife on a hand held radio.
replaced the store brand ICP sensor with a motorcraft sensor and the problem was solved.
Old Jul 11, 2023 | 08:51 PM
aawlberninf350
It's a Van Gogh
That's a good point, several cases like that. Dying next to local Sheriff's radio tower etc. So a burst with a nice strong radio added to the testing would be helpful.
Old Jul 11, 2023 | 08:58 PM
FordTruckNoob
So what you are saying is the ICP sensor needs to wear a tinfoil hat?
Old Jul 11, 2023 | 10:56 PM
John in OkieLand
I find it hard to believe, that the ICP sensor, which is buried in the block, is sensitive to Radio Waves....
Unless, the Harness is picking up the interference?
wrap the ICP leads and harness with aluminum foil, end of problem
Old Jul 12, 2023 | 12:07 AM
Tpayne621's Avatar
Tpayne621
I would more so see that being caused by a cps then a icp sensor. Never heard of interference on a icp sensor. But have experienced the interference from the windshield wipers on some cps first hand.
Old Jul 12, 2023 | 06:44 AM
helifixer's Avatar
helifixer
Cps is a simple yes / no signal
icp sensor is a computer and can be sensitive to rf signals.
Old Jul 12, 2023 | 07:13 PM
Higgins213's Avatar
Higgins213
😲😲 that's bonkers!! You would have thought that even if the ICP completely fried/failed that the PCM would just default, not kill the engine entirely. Interesting!
Old Jul 12, 2023 | 07:24 PM
Higgins213's Avatar
Higgins213
Wow! Tons of excellent info, thank you guys!!
Maybe instead of trying to get super technical with numbers and performances (which is a tad out of my wheelhouse, shocking as that may be) instead it'll be showcasing the visual differences between a genuine Motorcraft sensor and "ultra genuine pinky promise its OEM would I lie to you??" sensors that are plastered all over eBay.
Of the multitude of sensors I bought, a couple of them were extremely honest and noted that what they were selling was aftermarket and not made by Ford/Motorcraft, but a couple of them had the Ford/Motorcraft packaging in the picture, and are definitely trying to appear like the real deal.
If you guys are bored sometime maybe you'll get a kick out of this... if you go look on eBay for this sensor or something similar, there will be posts with Ford/Motorcraft packaging in the main pictures, but the actual words and/or the blue oval are blurred out. 😂
"Here, honey, here's a great price! The logo of the company is blurred out for some reason but I'm sure that's nothing to be concerned about! Grab me my credit card!"
Old Jul 12, 2023 | 08:17 PM
FordTruckNoob
You’d be amazed at how much trouble EMI can cause. One the major portions of the ground portion of an aircraft test program is EMI/EMC testing. We had one instance where the aircraft’s own radar made the new system we were integrating flip out. Makes one wonder just how safe the “safe zone” behind the nose cone of the plane really is.
