Air Conditioning
Old Jul 15, 2023 | 11:01 PM
molina505's Avatar
molina505
4wd Low
Air Conditioning
I have a 2002 F350 7.3 and I was wondering how to get the ac to blow more powerful. I’ve changed the blower motor, resistor and the evaporator is new.
Old Jul 16, 2023 | 02:23 AM
John in OkieLand's Avatar
John in OkieLand
Is the Cabin Filter clean?
same complaint on my daughter's car,
no air coming out of vents,
changed cabin filter, and wallah!!!
it blows hard now.
Old Jul 16, 2023 | 03:57 AM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
There is a max AC mod that works well, still rocking it on my truck.
Wow...REAL Air Conditioning!! - Ford Truck Enthusiasts Forums (ford-trucks.com)
Old Jul 16, 2023 | 07:04 AM
bsiliani's Avatar
bsiliani
it blows hard now.
There is no cabin air filter in that truck.
Cheap fix to improve on AC is install a ball valve on engine heater hose and close it in the summer.
Old Jul 16, 2023 | 07:41 AM
udsuth78's Avatar
udsuth78
Have you gone over the duct work checking for leaks. At their age it's a good possibility the foam that seals the joints has broken down some. I went through mine with a roll of rope caulk and plugged any air leak I could find. It made a noticeable difference in felt temp and force at the vents. The evaporator box was the biggest leak point, especially after opening it when I replaced the core. Another thing noticed by more than a few or us is the blower performance after switching to an aftermarket fan. They just don't seem to move as much air as the original Motorcraft blowers do.
Old Jul 16, 2023 | 07:45 AM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Deleted comment... I missed the part about the evaporator being new.
My apologies and I hope you find a resolution soon.
Old Jul 16, 2023 | 07:54 AM
pirschwagon's Avatar
pirschwagon
Not much you can do about that. However, put a vacuum solenoid into the Heater Core Line and connect it to the white vacuum line under the dash. When in MAX A/C the Heater Hose Valve is CLODED Automatically
Next put a RED Orifice Tube in the A/C. Mine blows about 54* Air Temp
Old Jul 16, 2023 | 10:44 AM
udsuth78's Avatar
udsuth78
A couple other things came to mind. You might check the fresh air vent door is closing during max AC. Up under the dash in the passenger footwell is the vacuum control actuator. Check that the vacuum line is hooked up and the door closes when in max AC. The blend door is another possibility and a somewhat common one. If the actuator has quit or even just dirty connection it can allow hot air from the heater core in w/ the cool and just kill the AC performance.
Old Jul 22, 2023 | 06:34 PM
gpracer1's Avatar
gpracer1
Trailering
I installed an adjustable low pressure cutoff switch and it blows a nice 30-35, not much humidity to worry about in AZ.
Old Jul 22, 2023 | 07:18 PM
RA101725's Avatar
RA101725
Banned
An adjustable low pressure switch? How does that work?
Old Jul 23, 2023 | 01:16 AM
josht's Avatar
josht
IIRC last year some guys talking about an addative that made the AC perform better. Was going to do it to mine, but never got around to that or installing the bypass valve. I think @Sous and @SkySkiJason were both in on the conversation since I recall it coinciding with discussion about one of the NGA G2Gs.
Old Jul 23, 2023 | 08:48 AM
jstihl's Avatar
jstihl
The performance enhancer is called cool shot ultra made by errcom. It works pretty well, I used it on my truck before I replace the entire AC system and it definitely helped some. As mentioned before the aftermarket blower motors do not push nearly as much air as the motorcraft units, I found that out the hard way.
On edit: x3 on the bypass valve, a 3/4 PEX ball valve fits perfectly in the line going to the heater core. Simple , cheap quick fix and it works.
Old Jul 23, 2023 | 10:31 AM
Kwikkordead's Avatar
Kwikkordead
I also am interested on the specifics of how this was done. I've done all the basic mods. Brass ball valve to stop the flow of coolant to the heater core. Verified that the evaporator is clean. (Removed the blower motor and looked inside. It looked clean as brand new inside and I was surprised to see that since there's no cabin air filter.) Made sure that the freon levels and the operating pressures are bang on the money. Still doesn't blow as cold as it should unless I put it on MaxAC, but then pretty soon I get that recirculated air smell. And yes, I've used that AC deodorant from NAPA.
Old Jul 23, 2023 | 04:03 PM
RA101725's Avatar
RA101725
Banned
As far I knew the low pressure switch on the accumulator was just a "dumb" switch that cuts the compressor off if low side pressure drops too low. What specific pressure that is, I'm not sure. There is a PID in ForScan for it called "ACCS" which basically just displays "off" when the system is off and "on" when one of the AC or defrost settings is selected with the dash **** to cut the compressor on. It does not report real time pressure readings to the PCM I was disappointed to learn like the MAP sensor does, or an aftermarket boost or fuel pressure PID, which would be helpful for diagnostic purposes on a cranky system that isn't working right (like mine). Same with the high side switch.
Old Jul 25, 2023 | 02:38 PM
gpracer1's Avatar
gpracer1
Trailering
Normally when the low side gets to about 25 psi, the compressor cycles off. This is to prevent freeze up of the evaporator, cycle off the compressor at very high rpms and shut it off if there is low charge.
If you have to downshift going up a hill or have low gearing and high rpms on the freeway it can cause your compressor to constantly cycle.
I replaced the low switch with one that I can adjust with the adjustment screw to lower it down to say 19 psi. The OEM 25 psi is about 29 degreesF at the evap core when it cycles off. So your air coming out will be at best 38 degrees with low humidity. Im in PHX so humidity is LOW, I can get down to about 20 theoretical degrees at the evap at about 19 psi. The truck does not normally run that low however unless high rpms or low blower. My air is real cold about 32 when cruising. It does nothing for idle.
