1996 E4OD shift problems
Old Jul 15, 2023 | 07:55 PM
BigDan1's Avatar
BigDan1
96 E350 based RV w460 ( 7,5L ) E4OD transmission ,
just had the transmission rebuilt with new torque converter
the tranny shifts in erratic way
I have to lift my foot on gas pedal for it to shift in 2nd gear otherwise it will stay in first gear
sometimes in od ,if I accelerate it will downshift in 2nd gear even at 60 mph
any advice
thanks ,
Dan
Old Jul 15, 2023 | 09:24 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
What codes are stored in the PCM?
Old Jul 15, 2023 | 10:06 PM
BigDan1's Avatar
BigDan1
no check engine
but dint think of checking if any codes ,Ill check tomorrow
Old Jul 15, 2023 | 10:29 PM
Mark Kovalsky
Most transmission codes will not turn on the check engine light, so that doesn't mean anything.
Old Jul 16, 2023 | 10:38 AM
BigDan1's Avatar
BigDan1
only code :111 ( all ok)
obdI Ford code reader innova
Old Jul 16, 2023 | 04:13 PM
Mark Kovalsky
What does the place that rebuilt it say? I think they did something wrong.
Old Jul 16, 2023 | 06:44 PM
BigDan1's Avatar
BigDan1
for now they dont understand
since it’s electronic controled , ill clean the connector ,hoping it could fix! 🙏
Old Jul 17, 2023 | 09:04 AM
ojh's Avatar
ojh
How many miles have you driven it? They DO act stupid when you reconnect power to them, 'Erratic' I think is how Ford puts it, they say you'll need about 10 miles before its gets itself sorted out.
Old Jul 17, 2023 | 01:45 PM
Mark Kovalsky
You're describing adaptive shifts. The 1996 that we are discussing here didn't have adaptive shifts, that started several years later.
Old Jul 17, 2023 | 06:04 PM
BigDan1's Avatar
BigDan1
Today : cleaned shift solenoid collector pins hopin……no change !
Decision
will change the shift solenoid unit ,hoping it will fix problem
Old Jul 20, 2023 | 01:42 PM
BigDan1's Avatar
BigDan1
Am I damned
changed the electronic shift control , nothing changed ,wont shift unless I lift my foot off the gas pedal , or either have to shift manually
even worse !
Came back home , put it in reverse to back up in my parking space , engine stalls , neutral,restart , reverse stalls 4 times, parked it forward for now
Îm desperate 🥺😩
Old Jul 20, 2023 | 02:56 PM
Mark Kovalsky
I think it needs to go back to whoever rebuilt it. It has serious internal issues.
Old Jul 20, 2023 | 09:47 PM
BigDan1's Avatar
BigDan1
what could it be ?
Old Jul 24, 2023 | 06:05 PM
BigDan1's Avatar
BigDan1
Did a complete check on my electronic shift solenoïd control.
pass all the tests ( resistance , solenoïd operation etc….) so ,ill put mine back in there ( found a complete procedure on youtube )
could it be a valve body malfunction ( cant see what else could be wrong ) tried to find a valve body tests instructions , dint find any
I’m fed up of this
thanks
Old Jul 24, 2023 | 08:03 PM
Mark Kovalsky
I can't see how it could be the valve body. I suspect there is a problem with the intermediate clutch.
