Start / run electrical circuit.
Old Jul 15, 2023 | 12:27 PM
SeaCarr's Avatar
SeaCarr
Not many wires but I'm hung up. Got the solenoid hooked up. Bumped the motor over. Went to wire up to ignition and can't seem to figure it out. Thought I had it this morning. Started by testing the switch. All looked good until I turned the key to start. Motor started cranking and would not stop with the key. Took loose all the ignition wires and had to jump out and unhook the battery. Simple but I'm stumped.
Old Jul 15, 2023 | 06:17 PM
spurredon's Avatar
spurredon
Kind of sounds like your solenoid got hung up or the ignition switch was stuck in the start position. What are you working on?
Old Jul 15, 2023 | 06:43 PM
SeaCarr's Avatar
SeaCarr
1959 F100. The switch returned to run.
Old Jul 16, 2023 | 11:36 AM
hiball3985's Avatar
hiball3985
I had the same problem with a new solenoid, more offshore crap. Returned it and the second one did the same, the third one finally worked ok.
Old Jul 16, 2023 | 12:16 PM
SeaCarr's Avatar
SeaCarr
Thanks for your reply. Something to think about. It is new from orielly's. Can't be sure anymore.
Old Jul 16, 2023 | 05:47 PM
spurredon's Avatar
spurredon
Brand new electrical components can be very perplexing. Ran into that with a new condensor once!
Old Jul 19, 2023 | 06:55 PM
SeaCarr's Avatar
SeaCarr
Thanks to all. Got it done.
partsman01
18
Apr 5, 2008 02:06 AM
big ol 84f150
Jan 8, 2006 04:50 PM
scott9320
Jul 31, 2004 08:02 PM
STEW
21
Jan 2, 2004 03:25 PM
4g63nt
Dec 27, 2003 09:37 PM
