starting with no key
Old Jan 7, 2006 | 07:48 PM
big ol 84f150's Avatar
big ol 84f150
i have an 84 f150 i have the key out and as soon as i connect the battery it tries to fire any suggestions?
Old Jan 7, 2006 | 09:18 PM
tjc transport's Avatar
tjc transport
i ain't rite
sticking solenoid.
Old Jan 7, 2006 | 10:34 PM
big ol 84f150
is that all it could be?
Old Jan 8, 2006 | 01:50 AM
81-F-150-Explorer's Avatar
81-F-150-Explorer
That is the most likely cause.
It could also be a shorted wire in the system, or a bad ignition switch.
The first thing I would do is change the solonoid.
You can test it by removing the start wire from the solonoid, and hooking the battery back up. If it tries to start, then it's the solonoid, if it doesn't hook the start wire back up, if it tries to start, then it's possibly the ignition switch.
Hope this helps...
Old Jan 8, 2006 | 11:59 AM
big ol 84f150
ok thanx i'll try it
Old Jan 8, 2006 | 03:04 PM
ford user's Avatar
ford user
i had the same problem here, it was a sticking solonoid. i also got a new solonoid that was bad and had to buy another.
Old Jan 8, 2006 | 03:16 PM
sierraben's Avatar
sierraben
big ol 84f150, let us know what the problem is/was.
Old Jan 8, 2006 | 04:50 PM
MRStace84's Avatar
MRStace84
I've had that one as well, bad solenoid......
ericconn
Apr 28, 2013 09:00 AM
Windsor84
Jun 11, 2006 12:29 AM
COMCARINC
Mar 19, 2006 10:01 PM
Windsor84
May 13, 2005 07:00 PM
