Shock Absorber Suggestions
Old Jul 20, 2023 | 07:56 AM
Charlie98's Avatar
Charlie98
FWIW, Ranchos have a lifetime warranty... pull them off, take them to 4WP or somewhere, and exchange them for new.
Last batch of Ranchos I got (for my '17 2500HD) one of the shocks was seriously under-damped... obviously a problem with the valving... so I wouldn't rule out a defect.
Also, FWIW, my '09 SuperDuty just has a very weak rear suspension, this truck didn't come with any sort of trailer or camper suspension upgrade, and it immediately wallowed with weight in the back (I carry about 800# in it daily.) I threw a set of Bilsteins on it, but as good as those are, they had very little effect on helping the springs carry weight.
Old Aug 3, 2023 | 11:40 AM
Bugzilla46310's Avatar
Bugzilla46310
How much is the tongue weight?
Old Aug 3, 2023 | 03:56 PM
Doug68's Avatar
Doug68
1st Gear
I had this problem with my F-150 + 7,500# TT. I tried adding airbags, which helped the rear axle stay planted while using a weight distribution hitch (I think that was amplifying my problem, but needed on the half ton). The solution to my problem was using the Anderson weight distributing hitch. It neatly eliminated all of the issue with undulation / porpoise-ing. I haven't found a rough road yet, or speed below 75 mph that gets me back to that crazy condition. It's a horrible feeling when things like that start happening at highway speed. I also agree with a couple of the other users recommendations with checking tongue weight (10-15% for TT) and the Lippert road armor seems like it would help. I don't have that on my setup, but perhaps I should.
Old Aug 6, 2023 | 07:11 AM
bowsniper's Avatar
bowsniper
I'm running about 1200 lbs of tongue weight, measured before the WDH is engaged. The WDH hitch definitely helps reduces the porposing.
Shernius
2015 - 2020 F150
Jan 31, 2023 11:12 PM
98ramtough
Dec 7, 2019 04:04 PM
DDT11
Jan 20, 2017 10:07 PM
Optimistic Paranoid
All Things Towing
Nov 10, 2015 09:22 PM
turbo2256d
Jun 2, 2006 12:34 AM
