Shock Absorber Suggestions
Thanks!
Often it is the road in my experience. My friend rode along to pick up some equipment in SLC. He tends to badly overload his truck with tongue weight because he thinks it fixes this problem. I loaded the machine and we hit the road. It was porpoising a little at first and he started in on his diatribe about how I had the machine too far back. Within a few minutes the road surface changed and no porpoising for the rest of the 6 hour drive. without making any load adjustments.
You can try moving weight around in the trailer but not many options with a travel trailer. You could try a set of monotube shocks. You could make adjustments to your weight distributing hitch if using one. Good Luck
there is no amount of suspension tuning you can do that will eliminate it completely on any jointed concrete road. The only thing you can do is travel at a speed that eliminates the resonance between the suspension and the profile of the joints on that road at that time of day. Try traveling at slower speeds and you will likely find a speed that doesn’t resonate with the road.
FWIW, we are currently kicking off a big research project at work directly related to this phenomenon. This is not an unknown problem for DOT’s but the ultimate solution is not readily apparent. This is because the profile of the road actually changes from hour to hour and day to day. Our research project is focused on developing a way to accurately measure the road profile, determine how it will react to heavier vehicles and develop a treatment method to help mitigate the effects of what we call “warp and curl”.
if successful, we will be able to predict what roads are going to be a problem before they generate complaints and treat them proactively rather than reactively as we currently do.
hate to say it, but all you can do is slow down. Sometimes you can speed up and get above the resonance, but usually that speed will end up in excess of the posted speed limit.
shifting the load can help also as stated above because it changes the tuning frequency of the vehicle’s suspension. But as above, there is only so much you can do with a travel trailer.
doesn't matter how the horse trailer is loaded either or even empty.
That said, a couple of questions:
1. What setting do you have the front Ranch 9000XL shocks on?
2. What WDH do you have and how confident are you that it is setup properly?
3. How well is the weight distributed within the trailer?
I can reduce porpoising by increasing the setting on my Rancho 9000XL shocks. It won't eliminate it but it does help. If my WDH isn't setup right I'll get more porpoising. I'm satisfied with how my Rancho shocks perform. I recently developed a vibration that I'm trying to figure out. Changing the shock setting didn't help. The tires were rebalanced, but I haven't had a chance to test that. However, since the tech said three tires were OK and one was off by only 1 oz, I suspect that the tire balance isn't the issue.
The setup isn't achieving resonance frequency because it does dampen out, but it is definitely under damped. The problem has become worse, so I'm thinking that maybe the Ranchos have worn out, even though they are only three years old. That's why I was thinking a heavier shock would help, one that isn't overworked and wears quickly. I admit that I have little experience with different types of shocks. Stiffer and more shock should improve the damping, but maybe sacrificing ride when not towing. It would seem that adding shocks to the TT would help, but without knowing for sure, I'm probably not going to start an experiment of welding shackles to the TT. With shocks being a big debate on the main forum, I was hoping you guys might have a preference.
Thanks!
Thanks!
I say all of this just to indicate that you could have vastly different ride characteristics within any roadway segment that would give the same ride effect as a problem with damping. It could very well feel like your truck was bouncing forever from a roadway defect, then come out of it, then go back into that same underdamped feeling several times within a mile or two all because of the changing profile of a jointed concrete pavement.
Now, all of that said, your shocks could also just be worn out and unable to control the load. If that's the case, get new shocks and replace them when you start seeing the same problem again.
I've never tried the adjustable Ranchos. I've got Bilstiens on my expedition and all-in-all, I'm not that happy with them. They ride good. they offer good control, but they weren't the night and day difference i was expecting compared to the stock units. They both rode good and offered good control. The factory struts were still good at 90k when I replaced them (except one leaker in the front). Now with about 75k on the bilstiens, i can tell the fronts are losing their ability to control the wheels under sharp inputs. I paid a premium for the bilstiens under the assumption (and sales pitch) that the mono-tube design would last longer than a twin-tube design. I have not found that to be the case. So i spent $1200 on struts and installation for units that rode as good as the factory struts and didn't last as long. Not exactly a win IMO. I could have gotten the Gabriel Ultras that ride as good, and cost half as much (installation is still a killer on an expedition). I will not buy bilstiens again. I recently put shocks on our F250 and i got the Gabriels. No need to spend the extra IMO.
So, get what you think will work for you and replace them when you start seeing a problem.
JMHO
Fast forward a year. The wife complains about "her stuff" inside the RV being bumped and moved around when we travel. I watch a few YouTube videos and see people reporting how dampened equalizers make a huge difference in the smoothness of the RV ride. After watching several videos describing the differences between the various types I decided to buy the Lippert Road Armor equalizers. Hey, while you're there you may as well get rid of the crappy nylon bushings and dry bolts holding the leaf springs and equalizers and install a wet bolt kit with the proper length shackles and bronze bushings. Off to etrailer.com I go.
The Lippert Road Armor kit has rubber dampeners on both sides of the equalizer. The MORryde kit only has rubber on the upper side of the equalizer. Hmmm. I opted for the Road Armor, thinking that rubber on both sides would offer better dampening of spring and axle movement. Now to get the wet bolt kit with shackles and bronze bushings to hold it all together. Hmmm - the Lippert kit is $300 and it doesn't include the bronze bushings to replace the nylon crap from the factory - they are an extra $60. Wait - MORryde sells a kit with the bronze bushings for $150. SOLD. I install the kits with my RV friend, hook up the Super Duty and we take it on the road for a test drive.
Lippert Road Armor Equalizers: https://www.etrailer.com/Trailer-Lea.../LC696740.html
MORryde Suspension Upgrade Kit: https://www.etrailer.com/Trailer-Lea...de/MR76ZR.html
Lippert Road Armor dampened equalizer. Note the heavy rubber cushions on both sides of the equalizer and the bronze bushings it comes with:
MORryde shackle & wet bolt kit with bronze bushings:
Road Armor and wet bolt kit installed on the RV:
As I tow the RV on the twisty road from my house to the two lane we noticed immediately that the RV suspension is silent because of the bronze bushings and wet bolts. Nice. I pull onto the two lane and take off. I am talking with my RV buddy about how quiet it made the RV axle movement when I realize we are approaching the 1st bridge. I don't have time to really slow so I just cross it at 50 MPH, bracing for the porpoise event. We crossed the bridge and ZERO porpoising occurs. Huh. I anxiously await the next bridge - it's about 3 miles up the road. We hit it at 50 MPH - same result. Next bridge - no porpoising. We continue on to the main highway, where there is a stretch that always causes the RV / truck to porpoise for about 1/2 mile or so and generally just feel less stable than preferred. WOW !!! It is so much better I can't believe it. For $500 and 3 hours of my time to install the kits I can't think of a bigger bang for the buck investment I've ever made in a vehicle.
This is one of the few times I can honestly say that a suspension "upgrade" actually made a real difference in the ride of the vehicle. I guess the rubber dampens the suspension movement enough to reduce or eliminate the resonance between the truck / RV combo and the highway joints. Whatever the case it is amazing how much better the RV tows with the change in suspension hardware. A bonus is now I can grease the RV to help keep it all moving smoothly. I am currently debating if adding shocks to the RV will help further with ride quality and RV longevity.
And yes, it did help with the amount of "stuff movement" in the RV that my wife was complaining about. I'm more excited by the towing improvement but we both got a win so I'll take it.
