System off to save battery
Old Jul 13, 2023 | 09:55 PM
GreenMountain95's Avatar
GreenMountain95
Hey everybody! I hope you're all doing good .
I've got a battery drain issue that I can't seem to pin down .
I just checked for parasitic draw , and I measured around 200 Milliamps (.2 plus amps) that i am losing when the truck is sitting there everything off .
ive got the system off to save battery message. I fully charged battery and let sit 8 plus hours to reset battery charge levels in the computer .
I read there's quite a few folks who get this message and did the manual reset trick (the brights flash brake pedal etc) and it does not work on my truck surprisingly!
At any rate I have an optima redtop . I have never had it changed to AGM battery in a tuner or anything .
When I got the message I checked voltage i beleive i was 12.2-12.4. Charged on battery tender to 12.8 volts. Drove about 10 miles half at highway speed and at destination still had message and then was at 12.4 volts !! Lost .4.
Threw new battery in optima redtop as i assumed it was the battery. Had the battery tested and it was still good . Now I've got a new redtop for my old f250 haha !
Any ideas appreciated !
I pulled all fuses in engine bay and no fuse lowered the amp drain .
Truck is a 2011 f150 lariat supercrew shortbed . 4x4 ecoboost .
On a side note when battery is hooked back up after disconnect the cd cycles through all 10 spaces it sounds like .
Old Jul 13, 2023 | 10:53 PM
steve(ill)'s Avatar
steve(ill)
several things... first is to charge the battery, you have to put the GROUND cable on the engine, not the battery.. The Battery Management System is monitoring the charge thru a block on the ground cable several inches from the battery.... Second, you have to wait 15 minutes or so after connecting the amp meter to see if the parisite draw drops.. There is some timer on the system...
What you might want to do is UNPLUG the BMS ( battery management system) for a few days and see if that fixes you problem..
Old Jul 13, 2023 | 10:57 PM
steve(ill)'s Avatar
steve(ill)
look at the drawing of the plug on Post #18 on this link...
https://www.ford-trucks.com/forums/1...nt-system.html
Old Jul 14, 2023 | 06:27 AM
projectSHO89's Avatar
projectSHO89
The "go to sleep" timer is about 40 minutes. If you measure current draw before then, you're guaranteed to go down a rabbit hole.
Old Jul 14, 2023 | 07:18 AM
GreenMountain95
Thank you for the advice, ill unplug the BMS for a few days and see how it does . I see the picture on that thread very helpful
i went negative and positive terminal first time I charged in vehicle. Then I read about the ground wire and the last charge was through the ground wire instead of negative terminal .
Okay gotcha ! So i need to plug in my amp meter and wait 15-40 minutes. Will do for next time .
Old Jul 14, 2023 | 11:22 AM
projectSHO89
40 minutes minimum. Period.
Anything less - rabbit hole.
Old Jul 14, 2023 | 06:26 PM
GreenMountain95
Gotcha! I'll get the meter hooked up and wait 40 minutes . I might even stretch it to 41 !
I about blew my meters fuse up when I opened the door the other day . 8 some amps went through meter when the lights came on and it's only good for 10 haha
Old Jul 20, 2023 | 07:22 PM
GreenMountain95
Well waited 40 plus minutes and found out my draw is only 12.8 milliamps ! Thats nothing!
So disconnect BMS for a few days and then hook BMS back up ?
Can anyone see any issues with the system computer not updated to the fact that I have an AGM battery right now instead of stock lead acid?
Old Jul 20, 2023 | 08:00 PM
RLXXI's Avatar
RLXXI
I disconnected my BMS sensor 9 years ago due to this issue. Not a problem since.
Old Jul 20, 2023 | 08:19 PM
GreenMountain95
I like the sound of that !!
Okay I'll disconnect and see what happens.
Old Jul 21, 2023 | 07:43 AM
RLXXI's Avatar
RLXXI
Unplug #10 as shown in this pic. DO NOT unplug anything else.
Old Jul 21, 2023 | 07:38 PM
GreenMountain95
Yep that's what I did just drove it truck ran great zero issues !! Thank you so much everyone have a great weekend
seventyseven250
2009 - 2014 F150
16
Jan 5, 2018 09:15 PM
DavidNM
Aug 29, 2017 05:11 PM
ac700wildcat
Garage & Workshop
Jul 23, 2010 07:11 PM
fishroe
2004 - 2008 F150
Aug 23, 2005 05:47 PM
aurgathor
Electrical Systems/Wiring
Jan 29, 2005 12:50 PM
