6.2L V8 Discuss the 6.2L V8
spark plug gap
Old Jul 8, 2023 | 03:51 PM
fordman19762003's Avatar
fordman19762003
spark plug gap
All the stuff to do the plug change on my 6.2 should be here by Wednesday so I plan on doing it next Friday. What are the plugs supposed to be gapped at? I know they come pre gapped but I like to double check them and I know some motors run better with a slightly modified gap from the factory setting.
Also, I know there is a torque spec for the plugs but with the minimal amount of room in the engine compartment I don't see how you're going to get a larger torque wrench to work. How tight are you guys putting your plugs when going by feel, like 1/8 turn past finger tight or more/less? I will be putting antiseze on the threads.
Old Jul 8, 2023 | 10:26 PM
rvpuller's Avatar
rvpuller
Veteran: Coast Guard
The gap is .044. I had no problem getting my torque wrench into the compartment with just a few extensions. I torqued mine to 25 DRY just like Ford did, they are a taper seat not a compression ring so do not turn them after they seat just torque them. Breaking the old ones loose takes a little effort so don't be afraid to pull on them to get them break loose. Be sure to change the wires, resistors and boots at the same time. Be sure to have a few extensions on hand, I found a swivel extension that worked great for #5 bottom plug.
Denny
Old Jul 9, 2023 | 06:26 AM
fordman19762003
Denny
25 in/lbs or ft/lbs? I have a bunch of extensions and a swivel end so I should be good to go there. Plan on changing everything except the COPs.
Old Jul 9, 2023 | 06:56 AM
rvpuller's Avatar
rvpuller
It's ft/lbs. The resistors can be hard to get out, just take a small screw driver and work them back and forth and then tap the coil on your bench to get it out. They tend to stick to the coil contact, you can use the same screw driver to clean the coil contact. If the resistor goes bad it will arc over it eating away at the coil housing that holds the resister in place.
Denny
Mumbly Joe
Jan 25, 2023 02:05 PM
Thumper47
1983 - 2012 Ranger & B-Series
Mar 23, 2019 01:51 AM
live2hunt
Modular V10 (6.8l)
Feb 27, 2013 06:54 AM
zarillus
Sep 1, 2007 03:15 PM
jjcaldwell
Modular V10 (6.8l)
15
Oct 14, 2004 02:28 PM
