2002 Excursion alarm disable
Old Jul 8, 2023 | 10:10 AM
mattbo505's Avatar
mattbo505
Does anyone know hoe to disable the back-up sensor alarm when towing a trailer? I know you can hit it to silence it when it starts beeping, but i was curious if there's a setting or trick to keep it quiet when i'm reversing my boat down the ramp or backing down my long *** driveway with multiple corrections.
Old Jul 8, 2023 | 05:29 PM
01__Excursion's Avatar
01__Excursion
So the Park Aid is something I just added. You are supposed to be able to push the dash switch and it lights up showing it's off. But every time you move the shifter out of reverse, then return to reverse, it resets, and you have to override with the dash switch.
Old Jul 8, 2023 | 05:54 PM
mattbo505's Avatar
mattbo505
Ya that's what i am currently doing and have been since i owned the truck. I didn't know if there was an override or not. It's just a PIA backing my boat down my long *** driveway and threading the needle into my driveway having to hit the "off" button every time i have to pull forward and correct a turn.
Old Jul 9, 2023 | 06:39 AM
01__Excursion
I get frustrated too, but other than a permanent disable like disconnecting the speaker, or unplugging the PAM box by the jack storage, that's how it's made to work.
Old Jul 9, 2023 | 07:57 AM
WE3ZS's Avatar
WE3ZS
There is this from Sammie up in the Tech Folder. https://www.ford-trucks.com/forums/1...l#post13746810
Old Jul 9, 2023 | 08:06 AM
mattbo505's Avatar
mattbo505
Awesome. i figured there was someone who had enough of that constant resetting. I'll look into it a bit more. Thanks for the find!
renoduckman
2021+ F150
Aug 1, 2022 11:10 AM
2019er
Aug 20, 2019 09:53 PM
Sleepyguy
Sep 7, 2017 09:12 AM
Laserman
Sep 14, 2015 05:54 PM
landk00
Nov 23, 2006 08:46 PM
