Trailer wiring
Old Jul 7, 2023 | 10:29 PM
Sparky04SD's Avatar
Sparky04SD
Trailer wiring
I'm towing my 95 F150 in signature and presently using a pair of magnetic based lights for rear of truck. I plug the cable into the 7 wire receptacle at hitch on my motorhome. I would like to build my own wiring harness for the truck - it consists of a 4PDT switch that allows me to choose which vehicle is powering the truck lights: for solo driving the truck powers the rear lights and when towing the RV powers the rear lights. I would mount the switch under the hood in a water tite j-box. The 4 pole switch would switch tail lights, brake lights, left turn and right turn. Ground wire would connect motorhome to truck. If necessary I could use the 12v "charge" wire to trickle charge truck battery as well. Is there a central location that the exterior lighting is located?
Old Jul 8, 2023 | 01:25 AM
wwhite's Avatar
wwhite
I think your wanting connector C205, pin 5, 6 and 23, for the rear.
5 - Right Turn Signal
6 - Left Turn Signal
23 - parking/driving lights
Images supplied by @subford
Old Jul 8, 2023 | 01:32 PM
Sparky04SD's Avatar
Sparky04SD
Is this connector C205 located under the hood by the relay/fuse box? Do the turn signal wires also activate the brake lights?
Old Jul 8, 2023 | 10:57 PM
x-ring's Avatar
x-ring
Don't know about C205, but the turn signals are the brake lights -- they're one and the same.
Old Jul 9, 2023 | 07:40 AM
subford's Avatar
subford
C205 is a safety wall (firewall) connector between the cab (passenger compartment) and the engine compartment.
ssurfer24
Sep 15, 2014 01:36 PM
abe
Jul 28, 2014 08:29 PM
patrickmcl
Nov 18, 2012 03:11 PM
bertha66
Aug 29, 2012 07:05 PM
02X72
Feb 3, 2009 09:25 AM
