lights not working
Old Aug 29, 2012 | 08:59 AM
bertha66's Avatar
bertha66
lights not working
Yesterday I was checking the lights on my race trailer that I pull with my 76 F250, with the trailer plugged in, I pulled the head light switch on; no lights on the trailer and all the lights on the truck except the head lights were off.
I unplugged the trailer ; no change. Then I starter the truck; all the lights on the truck came on. So I plugged the trailer in and they all work also. So I turn off the trucks engine and lights stay on. Then when I turned the lights off to fix a blub on the trailer and go to turn on the light again, something all over again.
Any ideas?
Old Aug 29, 2012 | 12:36 PM
fmc400's Avatar
fmc400
MSEE
The circuit in question (running lights) leaves the headlight switch as a BROWN wire and is independent of the headlights. The only thing that would make sense is a faulty headlight switch, and starting the truck may have jostled it enough to kick on. Power in and out of the headlight switch is completely independent of the ignition switch assuming your wiring has not been modified.
Old Aug 29, 2012 | 01:29 PM
bertha66's Avatar
bertha66
I will look at that head light switch. The wiring on this truck was made up of two wiring harness.
Old Aug 29, 2012 | 02:43 PM
fmc400's Avatar
fmc400
MSEE
In that case, then it's anybody's guess as to what's going on. Factory wiring diagrams are out the door if the wiring has been touched.
Old Aug 29, 2012 | 03:15 PM
jim collins's Avatar
jim collins
The head lights may have a breaker instead of a fuse and with a short in the trailer wiring it may be tripping and trying to reset itself. It may be a short that is small and maybe not happening every time. My $ 0.02 worth.___
Old Aug 29, 2012 | 07:05 PM
bertha66's Avatar
bertha66
Did nt find anything yet, but all the lights were working find today. but will look more into the switch. Thanks
~erik~
Jan 14, 2018 02:41 PM
SummerBreeze2
Dec 8, 2017 07:44 PM
patrickmcl
Nov 18, 2012 03:11 PM
fatcathp
Nov 27, 2008 04:03 PM
Rusty Trusty F-150
Electrical Systems/Wiring
Oct 29, 2004 07:11 PM
