I would tend to agree with you on that... and particularly the 'last screen' and 'seatbelt' screen part. I'm also a little taken aback by how crude... and how sloooooowwwww... the interface is. I came out of a '17 Chevrolet with basically the same level of display, and that thing would run rings around this junker. Commodore 64?
And I've also tried through FORScan and the manual way to disable the annoying seat belt reminder chimes...no dice. When you're driving around your ranch, the last thing you need is the nanny telling you to buckle up at 5 mph.
I'm ready for the update that brings the compass back, that enables the gauge cluster to remember the last screen, that gets rid of the stupid seatbelt screen, and that stops re-enabling the stupid trailer tow navigation after you disable it.
And that's just after the first week of ownership.
I was wondering why there isn't a compass on the screen in the instrument cluster. I have an XLT so only have the small screen in the center. Was the compass on the 2022 and earlier?
They should have the compass right where I put the circle.
The compass was in the gauge cluster plain as day on my 2019 XLT.
There is a thread on here informing you how to disable the seat belt chime, It worked on mine. It's not the red seat belt light to go out. was a different light.
Yup, the ABS light. Tried it, couldn't get it to work, and I've done this on many vehicles, and it's generally a similar procedure with buckling/unbuckling the belts on each of them. Not working for the 23.
Currently getting some help to fix via FORScan. Thanks for the suggestion.
I was the last thread starter on that. I did finally have success with it... you have to insert and remove the seatbelt 4 times... not 3 like in the book... then the seat belt indicator flashes.
