92 stepvan
Old Jul 6, 2023 | 10:50 AM
David Baio's Avatar
David Baio
5th Gear
92 stepvan
I have a 92 gruman stepvan with a 351 w. the motor has efi and i wanted to maybe upgrade the motor to something easier to work on, im not sure if the transmission would shift. i already cut the massive wiring out, just want to make it basic no computer involved. the chassis is basically a e350 ford truck according to the title, i know it weighs about 10,000 pounds.can i get something from a junk yard or what
Old Jul 6, 2023 | 11:01 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
It depends on what transmission you have. If it is a three speed C6 it will still shift fine. If it is the more common four speed E4OD you'll only have fourth gear.
Old Jul 6, 2023 | 11:49 AM
tabijan's Avatar
tabijan
Easier to work on like a 351 with a carb?
Can you take the front apart to pull the engine?
Sixto
07 E350 5.4 192K miles
Simm7141
Oct 22, 2017 03:10 PM
83f-250
Feb 4, 2015 09:35 AM
Samsn4
Oct 27, 2013 01:11 PM
jwmustangman
May 8, 2007 10:01 PM
