Need help understanding tag on transfer case.
Old Jul 5, 2023 | 02:29 PM
Tyler576's Avatar
Tyler576
1st Gear
It's in a 1985 F250. Looking for a rear drive shaft, but I can't find the right one.
Old Jul 5, 2023 | 03:21 PM
Max Capacity's Avatar
Max Capacity
https://driveshaftstore.com/Ford-F250-Driveshaft-1985
That is a place I've had good with for my car. May be they can help, call them, great customer service.
or,
https://www.google.com/search?q=85+F...hrome&ie=UTF-8
Old Jul 5, 2023 | 03:24 PM
Max Capacity
https://www.ford-trucks.com/forums/1...tranny-id.html
Old Jul 5, 2023 | 03:26 PM
Max Capacity
What does the door tag say, here's mine,
Old Jul 5, 2023 | 03:34 PM
Franklin2's Avatar
Franklin2
From the 208 on the tag, I am going to assume you have a New Process 208 transfer case. Here are all the different types of transfer cases you could have on a 1985 f250.
Warner manufactured
New Process manufactured, flange output
New Process manufactured, slip yoke output
You can see there were two different types of 208 transfer cases, flange yoke would have the slip yoke male and female on the driveshaft, and slip yoke output would have the male on the driveshaft and that would slip up into the back of the transfer case. Which one do you have?
Old Jul 5, 2023 | 03:36 PM
Franklin2's Avatar
Franklin2
Here are all the different driveshaft combinations available for a 1985 f250.
155" WB, MT, 4x2, front section, New Process manufactured transmission
155" WB, AT, 4x4, front section
133" WB, MT, 4x2, 1 piece, New Process manufactured, Spicer manufactured axle
133" WB, MT, 4x2, 1 piece, Warner manufactured, Spicer manufactured axle
133" WB, MT, 4x2, 2 piece, front section, New Process manufactured
133" WB, MT, 4x2, 2 piece, front section, Warner manufactured, T-18 transmission
155" WB, MT, 4x2, front section, Warner manufactured, T-18 transmission
161" WB Chassis Cab, AT, front section
161" WB Chassis Cab, AT, rear section
161" WB Chassis Cab, MT, front section, New Process manufactured transmission
133" WB, AT, 4x4, slip yoke joint, Spicer manufactured axle
133" WB, MT, 4x4, slip yoke joint, Spicer manufactured axle
155" WB, AT, 4x2, front section
155" WB, MT, 4x2, front section, Warner manufactured, T-19 transmission
155" WB, MT, 4x4, front section, New Process manufactured transmission
155" WB, MT, 4x4, front section, Warner manufactured, T-18 transmission
155" WB, MT, 4x4, front section, Warner manufactured, T-19 transmission
161" WB Chassis Cab, MT, rear section, New Process manufactured transmission
133" WB, AT, 4x2, 1 piece, AOD transmission
133" WB, AT, 4x2, 1 piece, C6 transmission, Ford manufactured axle, 10 bolt cover
133" WB, AT, 4x2, 1 piece, C6 transmission, Ford manufactured axle, 12 bolt cover
133" WB, AT, 4x2, 1 piece, C6 transmission, Spicer 61 axle
133" WB, AT, 4x2, 1 piece, C6 transmission, Spicer 70 axle
133" WB, AT, 4x2, 2 piece, front section, AOD transmission
133" WB, AT, 4x2, 2 piece, front section, C6 transmission
133" WB, AT, 4x2, 2 piece, rear section, Ford manufactured axle
133" WB, AT, 4x2, 2 piece, rear section, Spicer manufactured axle
133" WB, AT, 4x4, flange joint, Ford manufactured axle, from 5/85
133" WB, AT, 4x4, flange joint, Ford manufactured axle, thru 4/85
133" WB, AT, 4x4, flange joint, Spicer manufactured axle, from 2/85
133" WB, AT, 4x4, flange joint, Spicer manufactured axle, thru 1/85
133" WB, AT, 4x4, slip yoke joint, Ford manufactured axle, from 2/85
133" WB, AT, 4x4, slip yoke joint, Ford manufactured axle, thru 1/85
133" WB, MT, 4x2, 1 piece, New Process manufactured, Ford manufactured axle
133" WB, MT, 4x2, 1 piece, Warner manufactured, Ford manufactured axle
133" WB, MT, 4x2, 2 piece, assembly (Warner T-19 transmission, with Ford axle)
133" WB, MT, 4x2, 2 piece, front section, Warner manufactured, T-19 transmission
133" WB, MT, 4x2, 2 piece, rear section, Warner T-19 transmission, Ford manufactured axle
133" WB, MT, 4x2, 2 piece, rear section, Warner T-19 transmission, Spicer manufactured axle
133" WB, MT, 4x2, 2 piece, rear section, w/o Warner T-19 transmission; Ford manufactured axle
133" WB, MT, 4x2, 2 piece, rear section, w/o Warner T-19 transmission; Spicer manufactured axle, from 8501 GVW
133" WB, MT, 4x2, 2 piece, rear section, w/o Warner T-19 transmission; Spicer manufactured axle, thru 8500 GVW
133" WB, MT, 4x4, flange joint, Ford manufactured axle, from 5/85
133" WB, MT, 4x4, flange joint, Ford manufactured axle, thru 4/85
133" WB, MT, 4x4, flange joint, Spicer manufactured axle, from 2/85
133" WB, MT, 4x4, flange joint, Spicer manufactured axle, thru 1/85
133" WB, MT, 4x4, slip yoke joint, Ford manufactured axle, from 2/85
133" WB, MT, 4x4, slip yoke joint, Ford manufactured axle, thru 1/85
155" WB, AT, 4x2, rear section, Ford manufactured axle
155" WB, AT, 4x2, rear section, Spicer manufactured axle
155" WB, AT, 4x4, rear section, Ford manufactured axle
155" WB, AT, 4x4, rear section, Spicer manufactured axle
155" WB, MT, 4x2, assembly (Warner T-19 transmission, from 6/85)
155" WB, MT, 4x2, rear section, New Process manufactured transmission, Ford manufactured axle
155" WB, MT, 4x2, rear section, New Process manufactured transmission, Spicer manufactured axle
155" WB, MT, 4x2, rear section, Warner T-18 transmission, Ford manufactured axle
155" WB, MT, 4x2, rear section, Warner T-18 transmission, Spicer manufactured axle
155" WB, MT, 4x2, rear section, Warner T-19 transmission, Ford manufactured axle
155" WB, MT, 4x2, rear section, Warner T-19 transmission, Spicer manufactured axle
155" WB, MT, 4x4, rear section, Ford manufactured axle
155" WB, MT, 4x4, rear section, Spicer manufactured axle
161" WB Chassis Cab, MT, assembly (Warner T-19 transmission, from 6/85)
161" WB Chassis Cab, MT, front section, Warner manufactured, T-18 transmission
161" WB Chassis Cab, MT, front section, Warner manufactured, T-19 transmission
161" WB Chassis Cab, MT, rear section, Warner manufactured, T-18 transmission
161" WB Chassis Cab, MT, rear section, Warner manufactured, T-19 transmission
Old Jul 5, 2023 | 03:38 PM
Max Capacity
Have you asked around the local junkyard to see if they have any ideas... How about a local auto machine shop. Not sure where you live, but around CT there are any number of old places I'd go to ask if needed.
Old Jul 5, 2023 | 03:55 PM
Max Capacity
https://www.car-part.com/cgi-bin/search.cgi
If the link doesn't work just google car-part.com That's the site.
eilersia
Dec 19, 2022 10:59 AM
ms1780
Jan 5, 2022 07:02 PM
BigBlue92
2009 - 2014 F150
Feb 4, 2021 09:02 AM
hobohilton
Oct 27, 2020 05:59 PM
boston8273
Nov 27, 2010 10:26 PM
