ODB bluetooth suggestion
Old Jul 3, 2023 | 12:36 PM
mattbo505's Avatar
mattbo505
Hey guys I’ve been trying to research for a scan tool since I switched to the PHP tuner and was curious what ODB bluetooth plug in you recommend and what has the best features to monitor engine parameters from my phone (if there’s any that do that) I have a boost and EGT pillar gauge, but didn’t know or can’t find any info on if the Bluetooth ODB will read others while driving.
Old Jul 3, 2023 | 01:42 PM
Moland's Avatar
Moland
3rd Gear
https://www.obdlink.com/products/obd...p/?ref=forscan
https://forscan.org/download.html
This is what i use.
Old Jul 3, 2023 | 01:47 PM
mattbo505's Avatar
mattbo505
that’s the one I have in my cart. Can you use it with forscan and basically have everything while driving or is it only for checking codes?
Old Jul 3, 2023 | 01:49 PM
mattbo505's Avatar
mattbo505
And the iOS lite version works well?
Old Jul 3, 2023 | 02:46 PM
Moland's Avatar
Moland
3rd Gear
yes you can use it while driving. Check/clear codes and run tests. I use Android but im sure the ios version works fine.
Old Jul 3, 2023 | 04:01 PM
mattbo505's Avatar
mattbo505
Awesome thank you that’s what I was looking for! Just something extra to be able to monitor while driving vs a standard code reader that just sits.
Old Jul 3, 2023 | 11:33 PM
Theboneskes's Avatar
Theboneskes
This is the one i have for a fraction of the price. Works with Torque Pro and FORscan too...dont waste your money on those expensive ones that dont do anything extra.
Panlong OBD2 Scanner Bluetooth OBDII Diagnostic Tool Car Code Reader Turn Off Check Engine Light Support Android Torque App https://a.co/d/hFSquu6
Old Jul 4, 2023 | 07:15 AM
mattbo505's Avatar
mattbo505
I just looked at it. It is significantly cheaper, but it doesn’t seem to specify what trucks it’s compatible with do you by chance have a part number or model number?
Old Jul 5, 2023 | 08:31 AM
Theboneskes
Im using it on my 2003 Excursion 6.0
Ive used it on a friends 2001 Excursion 7.3. Have one installed on our "beater" 2006 Chevy Traiblazer EXT 4.2 gas motor.
Its a bIuetooth dongle. Will work on every car/truck that has a OBD2 port.
Old Jul 7, 2023 | 02:03 PM
mattbo505's Avatar
mattbo505
So I ordered the Panlang and I cannot get it to show up in my Bluetooth connections any advice?
Old Jul 7, 2023 | 10:39 PM
LeftCoast6.8's Avatar
LeftCoast6.8
I use a cheap
WIFI scanner off of Amazon WIFI scanner off of Amazon
and OBD Fusion on my iPhone. I paid the fee for the Ford advanced pack and it gives me everything I could need.
Old Jul 8, 2023 | 06:38 AM
mattbo505's Avatar
mattbo505
I bought the pan Lang blue driver off of Amazon. It plugs in and turns on it will connect to the Chinese car, scanner QR code on the box. No problem, but trying to connect it to torque pro or forescan It doesn’t even show up.
Old Jul 8, 2023 | 07:57 AM
mattbo505's Avatar
mattbo505
I ended up just returning it and ordered a different one we will see.
mweetman
Mar 11, 2020 06:28 PM
Talyn
44
Oct 19, 2009 11:19 AM
Oversize
Aug 10, 2009 03:18 AM
Izzy351
30
Jun 23, 2009 09:45 AM
secondarychaos
15
Aug 30, 2008 05:33 PM
