Advice on U0101 TCM communication code
Old Jun 30, 2023 | 07:50 PM
dothedew192's Avatar
dothedew192
Hey everybody, hope everyone is kicking off the start to theyre 4th of july weekend right and proper! I'm hoping somebody can point me in the right direction. i was just hauling my mower and trailer down to camp to mow and as i slowed down for the driveway the truck slammed down a gear, the wrench light came on the dash, the transmission temperature gauge dropped to 0, the transmission temp readout on the tuner dropped to 0 and the shift indicator light went out. I used the tuner to check the transmission codes and it wont communicate with the tcm. the pcm communicates just fine and reads codes just fine. Thats how i got the U0101 code. The trucks a 2011 Ford f350 6.7 with the 6r140. It has 198,000 miles on it. I've had it for 100,000 miles now, it does have "the weight reduction" package when that was done, there was also a streetsmart performance valve body put in it as a preventative measure. This is the first actual issue i've had with the truck, ever, honestly. Just wheel bearings, brakes, shocks, maintenance stuff basically. The way it just suddenly happened points me towards a bad transmission control module, but first, is there any fuses that power it besides number 46? I can only find one fuse that powers the KAM on the thing. Is sudden failure of the tcm a thing? I would of thought it would lose a thing or two but its lost everything, from the shift indicator to the temperature sensor readout. Any advice or suggestions? Thanks everybody!
Old Jul 1, 2023 | 05:43 AM
senix's Avatar
senix
Did you shut it off and then restart it? Electronics need to talk to each other and that codes is an indication they were talking.
Check your wiring to the trans, check both batteries, disconnected from the truck to see if they are ok. Load test them.
268Fords
Mar 1, 2017 10:39 AM
bublitz3
Mar 19, 2012 05:34 PM
RyanMackD55
Jan 27, 2009 03:02 PM
phatf250
Dec 18, 2006 02:56 PM
dvfd12
Aug 7, 2006 02:47 PM
