Code P0603 ???
Old Jul 24, 2006 | 09:12 PM
dvfd12's Avatar
dvfd12
Code P0603 ???
I have 4" exh, Edge juice w/additude, Predator programer, and auto trans. I first cleared the codes before I installed the 60hp tune the only one in there was P0603. Then I installed the 60hp tune with hard shifts. Went for a drive and the SES light was on. I figured it was the MAP sensor or something like that, but it was the P0603 again. Can anyone tell me what this means? I know it's "Powertrain control module keep alive memory (KAM) error". I just don't know what this means to me.
Thank you for any help.
Old Jul 24, 2006 | 09:20 PM
CAT_man_963's Avatar
CAT_man_963
Nothing to worry about - that code is perfectly normal - you cause that code just by using the tuner on the truck. Also I don't think it will set the SES light.
Old Jul 24, 2006 | 09:24 PM
dvfd12's Avatar
dvfd12
Ok, thanks it was the only code that came up with the SES light on. I feel better now. I hadn't seen it listed anywhere else.
Can you explain exactly what it means?
Old Jul 25, 2006 | 12:12 AM
saleen1996's Avatar
saleen1996
My truck pulled that code before and my ses light never came on Im sure if i ran a check it will pull that code again!
Old Aug 7, 2006 | 02:47 PM
NChornet's Avatar
NChornet
It comes on whenever you plug the tuner in and sometimes when you disconnect the batteries. This is what the dealer will look for to see if you are running a tuner, but as I said it will be triggered when disconnecting the batteries as well.
