Code P0237
Old Jun 29, 2023 | 12:43 PM
robjs111's Avatar
robjs111
Code P0237
My 2001 f350 7.3 is pulling a p0237 code. Truck runs rough, bucks and sometimes stalls but restarts, check engine light comes on but for less than a min. Also battery light pops on but turns off right away. I replaced Map sensor and cps with a new motorcraft versions. Truck starts, idles and runs great except for issues mentioned above.
Thanks.
Old Jun 29, 2023 | 01:20 PM
udsuth78's Avatar
udsuth78
Next move for me would be replacing the pigtails on the MAP sensor. Probably got a bad wire or pin.
Old Jun 29, 2023 | 01:26 PM
Jimmy's Pilot Service's Avatar
Veteran: Navy
Where did you get your MAP and CPS????
Have you pealed back the wire harness and insured it is in good shape?
What are you using to pull codes?
Old Jun 29, 2023 | 02:33 PM
robjs111's Avatar
robjs111
Replaced map pigtail.
CPS, MAP and map harness all purchased from riffraff
Using forscan lite to pull codes.
I have done ebpv, fuel bowl and iac delete but that was several years back. I did nothing with wires from deleting above items and pulling soft codes from.
could one of the deletes possibly cause issues? Wondering if port on x section of intake where map plugs into could be clogged?
thanks
robjs111
Jul 5, 2023 05:12 PM
yeterp
Aug 24, 2016 10:14 AM
f1501987
13
Mar 30, 2012 05:58 AM
Alpine6
Sep 8, 2007 10:28 AM
IM1096
Mar 29, 2007 09:02 PM
