more ignition problems
Old Jun 29, 2023 | 11:42 AM
bullnosebuford's Avatar
bullnosebuford
1985 f150. You guys know this thing by now all it has is problems. So my pick up coil went bad and was causing a timing issue, took distributer apart and put it all back together, no issues there. it sparks.
put it back in truck, and now the timing is impossible, put it at #1 TDC and set the distributer to #1 and now it runs like it’s sucking vacuum. I know all vaccum lines are good so that’s not The issue. Neighbors are sick of hearing it idle like **** so I need to figure out the issue.
TLDR: rebuilt distributer, set timing, and I can’t advance or retard it enough to make it run not like garbage.
Old Jun 29, 2023 | 04:06 PM
Franklin2's Avatar
Franklin2
Why can't you advance or retard it enough? You are using a timing light?
tbruz
Jun 8, 2016 03:09 PM
The Terrible Blob
13
Feb 1, 2014 08:00 PM
cowboy_tevlin
Dec 10, 2009 09:18 PM
mudslingur
Feb 23, 2007 09:42 AM
tx64f100tx
Feb 12, 2006 02:37 AM
