Sponsored by: Real Truck
Newb questions
Old Jun 27, 2023 | 05:49 PM
osualum78's Avatar
osualum78
8th Gear
Newb questions
I'm sorry for the newb questions, but I tried searching and didn't find exact results I was looking for. I know the below is subjective, but please try and be nice with my newbness and as objective as possible.
2015 F250, 6.7L diesel, Platinum crew cab, basically bone stock. I do have the factory "heavy" front end, it's on factory sized Fuel wheels (20") on 35x12.50's with a steering stabilizer and has a roll up tonneau cover, and has Airlift helper air bags in the back for towing.
I'm thinking about doing some light work to it.
It has the undersized 26G fuel tank. I want more range. I don't need to go boss sized, just more than 26G. Looking for easy take out of the factory tank, swap in the new tank. Not looking for anything like past rear axle or in the bed, aka a transfer tank.
I've seen the S&B (56G from them, 56 Gallon Replacement Fuel Tank for 2011-2016 Ford Powerstroke 6.7L Cr – S&B (sbfilters.com) and Titan (50G from them, 2011-2016 Ford Crew Cab, Short Bed SUPER SERIES (7020211) (titanfueltanks.com). Are these the go 2 aftermarket tank manufacturers? Pros and cons of each? It appears I have a skid plate around/on my factory tank setup? Would like to retain if possible. I also want the highest hanging aftermarket tank possible, e.g. I don't want one hanging real low. Best option?
Also looking to the following parts mods:
Cold Air Intake for 2011-2016 Ford Powerstroke 6.7L – S&B (sbfilters.com)
Cold Side Intercooler Pipe for 2011-2016 Ford Powerstroke 6.7L – S&B (sbfilters.com)
Body Mount Kit for 2008-2016 Ford Super Duty Crew Cab 5.4L, 6.2L, 6.4L – S&B (sbfilters.com)
MAP Sensor Spacer Kit for 2011-2019 Ford Powerstroke 6.7L – S&B (sbfilters.com)
Good or bad? Worth the cost? Better brand/version available?
I also saw that S&B is coming out with a hot side aftermarket pipe next month? Should I buy too when it is available?
Old Jun 28, 2023 | 09:15 AM
ShelbyHauler's Avatar
ShelbyHauler
All the tank replacements I have seen, the tank sits an inch or more below the factory tank to get the extra capacity. This means you can not keep the factory skid plate.
Old Jun 28, 2023 | 10:02 AM
redford's Avatar
redford
FTE Leadership Emeritus
Welcome to FTE.
You should also discuss your engine modification questions on the 6.7L PSD engine forum. Some of those members don't visit the Super Duty forums.
602Alan
Dec 31, 2022 09:32 PM
Hkats
Dec 29, 2019 08:34 PM
Superdave71
Mar 1, 2017 08:54 AM
Skyline Drive
Jan 2, 2012 06:03 PM
zsir
Jul 6, 2003 05:14 PM
