2000 E350 hpop rear plug
Old Jun 27, 2023 | 03:55 AM
Badcompany1993's Avatar
Badcompany1993
3rd Gear
I have a E350 powerstroke van. Is leaking oil from the plug behind the hpop how can I replace it with so limited room to work on? Can it be done from the rear of the engine or could I lift the van cab off the chassis to get more room to work on?
Old Jun 27, 2023 | 09:25 AM
RacinJasonWV's Avatar
RacinJasonWV
Welcome to the forum!
Are you talking about the small “non-serviceable” plug? I’m pretty sure the HPOP has to come out to repair that one. There’s a check ball that will fall out of place so the pump has to be out.
Riffraff and other reputable sellers have a longer plug service kit for it.
Old Jun 27, 2023 | 06:07 PM
Badcompany1993
3rd Gear
Hpop read plug
No am talking about the rear plug that is parallel with the IPR. I seen a few YouTube videos where they replace the seal but is done on pick ups not on vans.
Old Jun 27, 2023 | 10:22 PM
FinnishStroker's Avatar
FinnishStroker
I have sealed the HPOP rear plug in a van.
Remove the air filter assembly and turbo intake snorkel.
Then you should have access from under the hood.
It can be done but is a major PITA.
Old Jun 27, 2023 | 11:46 PM
Badcompany1993
3rd Gear
Thanks for the help I'll try to do it that way
kevinvinv
May 22, 2023 09:11 PM
Resendiz
Jun 21, 2017 05:40 PM
tinker934
Jan 27, 2009 05:02 PM
huskeyone
Aug 6, 2001 10:49 AM
