Hpop help in a van
the dog house and can see the drivers sidebottom of the pump is leaking.will ford's service kit have the o rings that i need for this job. And do i pull the hpop out to do this one ???because there is no room like the
trucks to work on it
You'll need to figure out if you need the o-rings for the end plug, lines, or if it's the so called non-serviceable plug. That or buy something for all of them.
You can probably save quite a bit of money by ordering the o-rings here Replacement O-rings for Diesel Engines
I really don't know what it's going to take to be able to reach this stuff on the van.
