Catch can?
Old Jun 26, 2023 | 08:14 PM
Inxs F100's Avatar
Inxs F100
4wd Low
Catch can?
Hi all, new guy here. I just got a 1971 F 100, 360 Holly 2 barrel 4 speed. Oh, Hump side? Doing a cleanup, the aluminum hose from the passenger side of the air cleaner cover is in pieces. It runs down to the passenger side frame next to the radiator. Can all this be replaced or upgraded?
If so web sites would be helpful.
Thanks
Old Jun 28, 2023 | 05:28 PM
FuzzFace2's Avatar
FuzzFace2
Sorry being late welcome to FTE
Any way for you to post a picture of this hose where it is from and to?
I am guessing this is from the air filter snorkel on the bottom and should go to a tin shroud around the EXH manifold to trap heat.
Where the hose hooks up has a valve and when the air and motor are cold the valve lets hot air to the carb to help it run till up to temp and keep the carb from icing up.
As the air and motor get warmer the valve moves to pull in cool air.
As for this tin most of them rust and turn to dust and why you may not have one on the motor.
As long as the hose is close to the manifold, use baling wire to hold it in place.
Dave ----
Old Jun 30, 2023 | 06:27 PM
Inxs F100's Avatar
Inxs F100
4wd Low
picts
Old Jun 30, 2023 | 11:59 PM
RichS2659's Avatar
RichS2659
It is the old evaporative emissions system where fuel vapors are sucked from the tank, stored in the charcoal canister, and then routed to the air filter where it is burned. Unless you live in a green commie emissions state, just delete it and plug the air filter hole and fuel tank hose.
https://www.fordification.com/tech/i...ank_w-evap.jpg
Old Jul 1, 2023 | 12:38 AM
Inxs F100's Avatar
Inxs F100
4wd Low
Thanks for the info.
Old Jul 1, 2023 | 07:12 PM
FuzzFace2's Avatar
FuzzFace2
If me, because the truck looks so factory I would try and replace that hose.
You dont see many old cars & trucks that look factory under the hood.
My 81 F100 with a 300 six has some of the smog stuff re-moved but it looks factory when the hood is open at shows.
But as they say it is your truck to do as you want with.
Dave ----
Old Jul 1, 2023 | 07:53 PM
Inxs F100's Avatar
Inxs F100
4wd Low
Still stock, except for the Holly.
Old Jul 2, 2023 | 04:58 AM
FuzzFace2's Avatar
FuzzFace2
That is cool as it is under the air filter and cant be seen.
I have a non-Ford car I did the same thing, Holley 2300 v2 under the factory air filter.
I wounder where you can get that hose as I have not seen it anywhere, but also not looked for it.
BTW nice looking truck,
I bet you get a lot of people giving thumbs up and wanting to talk about your truck.
Do you take it to any Cars & Coffee, cruise in's or shows?
My 81 F100 flare side looks factory stock other than the after market wheels, only wheels I have for the truck.
Dave ----
Don Vito
Dec 28, 2015 07:28 PM
99StrokeXLT
Aug 20, 2014 01:00 PM
John R. Thomas
Jul 29, 2013 05:39 PM
VaFordman26
May 13, 2013 03:06 PM
GeneStoner
Jul 8, 2005 10:51 PM
