2019 6.7 towing 42 ft fifth wheel
The following users liked this post:
What temperature were you seeing?
What is the actual weight of your trailer as you were having this issue?
Just because the clutch fan comes on high and you see the temp guage rise to the other side of center does not mean it is overheating.
At that spot your coolant is only about 220F if you put a guage on it.
Oil temps are fine up to 248F and you were not there.
With my 2013 I could take Monarch pass at speed or even the Eisenhower Pass without issue.
If the clutch fan comes on like an airplane then let it do its thing.
The following 2 users liked this post by senix:
Doesn't hurt to make sure the engine air filter is clean and spray a garden hose both directions through the cooling stack. Even if the A/C condenser, intercooler, and radiator look clean, fine dust can build up and make a difference.
The following 2 users liked this post by '65Ford:
If this is abnormal for your truck and camper you may have been facing a very stiff headwind without realizing it due to power of the truck. The truck may have been working harder than you realized. Couple years ago our truck was running warmer than normal and fuel economy was way down. Then I realized the grass was blowing down flat in the opposite direction !
And what makes you think it derated in power?
pecora55
Toy Hauler Towing; Fifth Wheel & Bumper Pull
10-17-2022 07:02 PM
mwebster22
Fifth Wheel & Gooseneck RV Towing
07-06-2021 01:06 PM
cabindoc
05-23-2021 12:11 AM
Work Truck Fanatic
07-22-2020 08:22 AM
