No, it isn't an air in a line problem. A transmission does not need to be bled. The problem is a bad seal, or a mis-seated torque converter, or a mis-assembled valve body, or something else making a large internal leak.
Getting it to partially engage at high RPM has destroyed a clutch. Take it out, it needs to be rebuilt.
